Smog pump ?
Old Jun 16, 2017 | 11:38 AM
Genecarroll's Avatar
Genecarroll
Default Smog pump ?
What is this part called on the smog pump or a part# please
Old Jun 16, 2017 | 12:46 PM
grantv's Avatar
grantv
Garbage?
Free bump​​​​​​; try Vettenuts or FS section if you need one.
Old Jun 16, 2017 | 12:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,,,,,,,,, Its NOT a SMOG pump. Its an A.I.R. (Air Injection Reaction) Pump. The pump runs at engine start up for approx. 2 min. to inject FRESH AIR into the exhaust pipe before the O2 Sensors to allow the CATs to light off and come up to temp faster. Then it shuts off.
The PCM can command it on during part throttle operation to check for A.I.R. System & pump operation. The PCM monitors the output signal of the O2 sensors while the pump is running and that change in signal tells the PCM all is good or bad.
That part is a VACUUM OPERATED Valve that opens when the PCM commands the pump on. The PCM turns on a solenoid valve that allows manifold vacuum to the small port on the valve and the valve opens to allow the AIR Pump output to go to eash A.I.R Check Valve.
Old Jun 16, 2017 | 02:06 PM
Genecarroll
One of the hose nipples on mine rotted and broke off. So trying to locate just that part somewhere.
Old Jun 16, 2017 | 02:28 PM
Genecarroll
Found it thanks
Old Jun 16, 2017 | 02:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just go to Home Depot and find either a:
Plastic or brass nipple that you can screw into the cover of the valve or
EPOXY a nylon or brass nipple on to the cover of the valve.
To Smog pump ?
