Identify gear ratio
Old Jun 22, 2017 | 06:56 PM
bamavette11's Avatar
bamavette11
AL Events Coordinator
Default Identify gear ratio
Is there a way to determine what the gear ratio is on a set that is out of the pumpkin? There is a local set of advertised 3.42 I want to look at but would like to know if there is a way to identify the ratio. I would hate to go through all of the trouble of changing them and then not be a 3.42
I can post a pic if that would help
Update: I found the info, teeth count 41:12 = 3.41666 41 teeth on ring gear and 12 on the pinion gear
