Power window button on '99
Old Oct 1, 2002 | 12:40 PM
MSBHVN's Avatar
MSBHVN
Default Power window button on '99
Any suggestions on what's going on and how I can fix it? Drivers side window tempermental-sometimes won't work, other times does! No problems with passenger side.
[Modified by MSBHVN, 4:59 PM 10/1/2002]
Old Oct 1, 2002 | 08:46 PM
Bandit1's Avatar
Bandit1
Default Re: Power window button on '99 (MSBHVN)
If you don't have a volt-meter, get into the switch control panel itself, swap the wiring fron driver window swich to the passenger window switch and see if it does the same thing. If it does, its the switch and will require R&R, if it doesn't then its the driver window regulator and it will require R&R. :smash:
