Shocks changed, I have a problem - help!!!
Old Jul 8, 2017 | 08:43 PM
Jose2SS's Avatar
Jose2SS
Default Shocks changed, I have a problem - help!!!
So, I replaced my 1998 Corvette 4 shocks, all fitted perfectly, when lowered and tested driver front side is around 1.5" higher than passenger side. I went back and dismounted everything to verify, installed them back and issue persisted. Ride height screws verified and are exactly the same, all screws verified, I rode it twice through rough curves and bumps and still the same, any suggestion???? Please help!!!
Jose C.
Old Jul 8, 2017 | 08:47 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
pics? of install
that's just odd
Old Jul 9, 2017 | 12:51 AM
Awkwardcrane's Avatar
Awkwardcrane
Aren't the fronts and backs different? Any chance fronts on one side etc. I'm talking from no experience, just a thought.
Old Jul 9, 2017 | 02:59 AM
Rob 02's Avatar
Rob 02
Maybe one of the shocks is defective and wont compress.
Old Jul 9, 2017 | 07:03 AM
helga203's Avatar
helga203
They are. They will not fit if you don't know front to back shocks. Like putting a square in a round hole.
Old Jul 9, 2017 | 07:52 AM
vettenuts's Avatar
vettenuts
Is it "higher than before" or "higher but more level"? Are they gas charged shocks? A new gas charge may hold the car a bit higher than prior, especially of the fronts were really shot.
Old Jul 17, 2017 | 02:44 PM
Jose2SS's Avatar
Jose2SS
There is a difference from around 1.5" from one front side to the other. Measuring it from the tire to the fender. I have tried everything, I am running out of ideas. Used the car several times, called the vendor and his response was like he has a very bad day.
No support or options at all, at one point in time he asked me "Ok what do you want me to do?" the least I was expecting was for them to ask me for pictures or if I had used the car, but nothing, just attitude. From me one less customer.
Old Jul 17, 2017 | 03:31 PM
KCK8766's Avatar
KCK8766
What shocks are the new ones?
Did you forget a rubber bushing on top of shock?
Old Jul 17, 2017 | 04:06 PM
Jose2SS's Avatar
Jose2SS
Here is the part number and vendor:
Manufacturer: GM
Part Number: 10313647
Part: Shock Absorber
Part Notes: Corvette. Without z06. Sport suspension. Z06, zr1 & grand sport. Base & 427, fe3: sport susp.
GM part number 10313647 is a Genuine GM Shock Absorber and is guaranteed by a factory backed GM Parts warranty. We sell GM Parts and GM Accessories with great customer service and are knowledgeable about the products we sell.
GM OEM PARTS
CULTRAG Performance is an independent reseller of Genuine GM Parts. GM Parts come with a 12 month unlimited mileage warranty from the date of the sale. The warranty does not cover parts that are defective due to being modified or improperly installed. Should you have a defective part during the warranty period please contact CULTRAG Performance.
Old Jul 17, 2017 | 04:43 PM
vettenuts's Avatar
vettenuts
I thought it was off front to back, not side to side in the front. I would carefully examine the spring for cracks, won't be the first time a spring has failed.
Old Jul 17, 2017 | 06:20 PM
twokbolt's Avatar
twokbolt
How exactly are you getting your measurements?
Old Jul 18, 2017 | 01:23 PM
Jose2SS's Avatar
Jose2SS
It is pretty obvious the difference from one side to the other. I am confirming it with a measuring tape from the top of the tire to the fender edge, and btw the tires are new too, so they would not be the difference.
Old Jul 18, 2017 | 01:24 PM
Jose2SS's Avatar
Jose2SS
Sorry to ask this rookie question, what spring should I look for? There is no spring on the front suspension, just the shocks and the arms.
Old Jul 18, 2017 | 03:15 PM
bj1888's Avatar
bj1888
Are the lowering bolts set roughly the same on each side?
Also, sit in the driver's seat and have someone measure; it's possible that the car is adjusted to be level with a driver in the car.
Old Jul 18, 2017 | 05:20 PM
twokbolt's Avatar
twokbolt
Measuring tire to fender gap is not the best way. Try this:
https://www.corvetteforum.com/forums...post1574392685
Old Jul 19, 2017 | 03:13 PM
Jose2SS's Avatar
Jose2SS
Got it, went and verified the springs, both bolt nuts are at the same level. Still looking for anything else.
Thanks all for the responses!!!
Old Jul 19, 2017 | 03:47 PM
Rob 02's Avatar
Rob 02
Any loose suspension components like ball joints?
I assumed that you checked to see if the shocks can move freely through their range of travel.
To Shocks changed, I have a problem - help!!!
Old Jul 20, 2017 | 12:47 PM
Jose2SS's Avatar
Jose2SS
Yeap, all that verified. I will be lifting it today on a shop in order to verify the springs and rubber supports that goes on them.
Old Jul 20, 2017 | 02:19 PM
wallysolvette's Avatar
wallysolvette
Have you tried switching the shocks from one side to to the other side. This would eliminate the problem to the shocks if one is bad.
Old Jul 21, 2017 | 02:09 PM
Jose2SS's Avatar
Jose2SS
Done, thanks!!! still same issue. I will just keep looking.
Thanks!!!
