pushrods
Old Aug 5, 2017 | 06:08 PM
  #121
Georgies's Avatar
Georgies
Originally Posted by 99blkfrc99
I've been lazy and haven't put my ac belt back on. I have the same pulley as you and I thought I read somewhere it should be a 400 not 395.
Does your ballancer have a larger diameter towards the block than the front?
Old Aug 5, 2017 | 07:01 PM
  #122
vettenuts's Avatar
vettenuts
Originally Posted by 93Polo
I am hopefully going to be reinstall my ATI dampner tomorrow. Should you put any oil on the front main seal during installation?
No, don't lubricate the seal where it rides on the hub.
Old Aug 5, 2017 | 07:05 PM
  #123
vettenuts's Avatar
vettenuts
I think you can put on the water pump as you should still be able to get at the A/C belt. Also, the rack if it is still out and get your steering shaft back on. Then the alternator bracket can go on. Just make sure you have access to the belts, i.e., don't install anything that will prevent correcting your current issue.
If you have an old belt laying around that is longer you could cut it and then holding the tensioner half way through the stroke install and put a line where it overlaps. That would give you a measurement. If you don't have an old belt, you might be able to use thin rope (don't stretch while measuring) that is the same thickness of the belt. That would give an approximation since they don't come in super fine length increments.
Old Aug 5, 2017 | 07:36 PM
  #124
Georgies's Avatar
Georgies
Thank you !!!!
Old Aug 6, 2017 | 11:03 AM
  #125
Georgies's Avatar
Georgies
I did what u said and cut the stock belt and got a measurment of 41 inches...
This is what i was able to get at yhe store. It fits.
Old Aug 6, 2017 | 01:34 PM
  #126
Georgies's Avatar
Georgies
It could be a little tighter...but cant find 41 inches
Old Aug 6, 2017 | 08:26 PM
  #127
vettenuts's Avatar
vettenuts
Wonder what one size shorter would be, and if it would fit.
When do you think you will start it?
Old Aug 6, 2017 | 11:38 PM
  #128
Georgies's Avatar
Georgies
Im very happy...I only forgot to plug the two rear 02 sensors. I will buy them tmr and do another sounds clip.
Also, when i tried to turn on the A/C it would blow warm air, and the light on the ac button would just keep shutting off...
And another thing, my sound system would keep shutting off...for a split second. You could hear very faint music during those split seconds..
This is what it sounds like warm. Stock Tis and the catless longtubes from ARH.
Thanks Vettenuts, for all the help, I owe you one!
Old Aug 7, 2017 | 07:11 AM
  #129
vettenuts's Avatar
vettenuts
Very glad you got it running. Sounds good. Any abnormal lifter noise? It will be louder than stock, but I didn't hear any loud noises in the video.
Check to see if that belt is not turning the A/C compressor when you turn it on.
I am actually heading for PEI in the morning
Old Aug 7, 2017 | 10:09 AM
  #130
helga203's Avatar
helga203
https://youtu.be/MMi1wq-GhX0
niiiiccccceeeeee
Old Aug 7, 2017 | 11:40 AM
  #131
Georgies's Avatar
Georgies
The lifters sound fine. I cant really hear anything, even with the hood up. If I stick my head down, I can hear a slight sewing machine sound( I know very well what sewing machines sound like, I'm in the textile business).
The exhaust is muffling any motor noise from what I'm understanding.
I had someone keep pushing the Ac button while i was looking at the belt, I didn't see any abnormalities or slippage. But the light keeps turning off about 3 seconds after you push it.
Also the check engine light goes on. When it does, it idles a little better.
Also if i delete the codes while driving, it really studders bad and I have a hard time keeping it alive...take about 45 second of playing with the throttle, then it starts idling OK.
I'm getting:
P0106 HC
P0140 C
P0160 C
And the Radio is okay now... I think its due to an update on my cell phone
Have a great trip man, hope you enjoy yourself , maybe get to go fishing?
Old Aug 7, 2017 | 07:19 PM
  #132
vettenuts's Avatar
vettenuts
I'm getting:
P0106 HC
P0140 C
P0160 C
I was actually surprised how well it was idling on the stock tune. Likely tuning will clear up the issues you are having except for the A/C.
Old Aug 7, 2017 | 10:45 PM
  #133
Georgies's Avatar
Georgies
Yes i hope so. Still trying to decide who to go to. Will a tuner also be able to get rid of Twillight?
Heres a video with the rear O2 sensors plugged up wih the motor at operating temp. It's a little bit more quiet but it sounds very good. I don't see how some guys run around with straight through mufflers especially in the city...
Old Aug 18, 2017 | 01:58 PM
  #134
helga203's Avatar
helga203
https://youtu.be/pBiPNmmppFA
any updates to share?? Running good? Fixed your codes????
Old Aug 18, 2017 | 04:57 PM
  #135
Georgies's Avatar
Georgies
Yes I went to a shop called Bonhomme Performance. I was very pleased with the way he worked. He put the sniffer in the wideband bumg of the x pipe. Also set redline to 6850 RPM. He said if we were to go higher rod bolts will be an issue.
He tuned out rear O2s. And also said he tuned out the air pump?? I have to look into that as my Halltech i take had no provisions for the air tube.
Im no extpert, so here are the results.
Old Aug 18, 2017 | 07:14 PM
  #136
Georgies's Avatar
Georgies
Do these numbers look okay for cam intake exhaust? Also, the AF ratio, i dont know much about all this stuff. Does it seem okay?
Old Aug 18, 2017 | 08:01 PM
  #137
helga203's Avatar
helga203
Wow, i believe those really good numbers. Stock heads?? Usually you have to put good heads on it to get those numbers or am i missing something??
Old Aug 18, 2017 | 08:17 PM
  #138
Georgies's Avatar
Georgies
Yes stock heads. The owner of the shop (the tuner) said its around 530 hp at crank.
