A/c actuater
Old Jun 28, 2018 | 05:30 PM
Kenneth Richerson's Avatar
Kenneth Richerson
1st Gear
Default a/c actuater
I have a 01 with duel climate and no matter the mode setting air blows from every orfic floor defrost and dash no codes checked fuses and relays nothing seems out of place we also hot wired the compressor it comes on but no cold air...any ideas? I'm at a loss any help would be appreciated
​​​​​​​thanks Kenneth
Old Jun 30, 2018 | 10:20 PM
sczo69's Avatar
sczo69
Hey man, it more than likely won’t throw a code for that situation. The chances are it’s either one or both of your a/c actuators or your head unit is malfunctioning and needs a rebuild. If it’s the head unit there are several people who rebuild them for a reasonable price but I would check to see if your actuators are working first. Those are quite pricey if you go exactly with what came off of it but there are decent new old stock ones in eBay for reasonable prices. Mine was the drivers side actuator where it was stuck on hot. I could manually rotate the gears to cold but it would stick in it so ended up replacing it and works like a charm
Old Jul 1, 2018 | 12:06 AM
Moved to C5 Tech.
Old Jul 1, 2018 | 03:35 PM
redzg's Avatar
redzg
thanks Kenneth
Air blowing out everywhere is symptomatic of loss of vacuum signal. Sadly common, very often due to broken plastic tubing under the battery. As to cold air, you noted you hot wired the compressor, perhaps indicating a lack of refrigerant. Separate problems - and exactly how my car was. I fixed the vacuum switching first, then had to change the compressor.
