2001 corvette coupe, error code p1416
Old Jul 27, 2017 | 02:00 PM
acat1234's Avatar
acat1234
Default 2001 corvette coupe, error code p1416
My 2001 corvette is throwing error code p1416 and the chevy dealer wants $450 to replace the passenger side check valve. Other than the irritating CEL light on, is there any harm caused if the valve is not replaced?
Old Oct 7, 2017 | 11:24 AM
acat1234's Avatar
acat1234
Default Continuation of passenger side air check valve saga
First - thanks for all the replies and suggestions.
I was very uneasy about removing/ replacing intake manifold and fuel rails. You would not believe how many simple jobs I have screwed up 😣. So I went to Chevy dealer in Northern ohio and was quoted $412 to replace valve. However 'vette mechanic said no real need to since it is only for cold weather startup and would not hurt anything if I just left alone -which I did. I did try the throttle body/WD 40 treatment but light came back on in a couple of days.
Drove 1300 miles to Florida ( with CEL light shining brightly for 18.5 hours) where I will leave it until next May.
Suddenly, after a few days in area just south of Fort Myers Fla, the CEL went off on its own and has not come back on after a couple of weeks.😎😂 Not sure why. But happy it went off😛!
Any further thoughts would be appreciated.
Last edited by acat1234; Oct 7, 2017 at 11:28 AM. Reason: Correctopic spelling errors and add info.
Old Oct 7, 2017 | 04:12 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Have them tuned out...What I did, then removed all the lines. Put blocks in place on the Ex. manifolds, or /as I did replace stock Ex. with headers... Then sent ECM/PCM TO CHUCK COW for tuning. Lov the sound and the tune....
mike v
Old Oct 10, 2017 | 11:05 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Thank you sir!
mike v
Thank you Mike!
Chuck CoW
Old Oct 11, 2017 | 09:35 PM
johnson-rod's Avatar
johnson-rod
The WD40 finally made it to the valve.
To 2001 corvette coupe, error code p1416
