error code c1217
Old Jul 29, 2017 | 06:11 PM
apalmer181's Avatar
apalmer181
2nd Gear
Default error code c1217
I have a 2000 c5 vette. Error code c1217 "pump motor shorted to the ground" appears on my diagnostic reader. Which pump motor, and how do i fix it?
Old Jul 29, 2017 | 06:19 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
https://www.corvetteforum.com/forums...post1584789543
Old Jul 30, 2017 | 04:38 AM
runner140*'s Avatar
runner140*
At least I'll say it....thanks.
P.S. and answered him in 8 minutes.
Old Jul 30, 2017 | 12:42 PM
apalmer181's Avatar
apalmer181
2nd Gear
Got it. Now I guess I have a lot of work to do. Thanks much for the info.
Old Jun 24, 2020 | 02:07 PM
Joe Arismendy's Avatar
Joe Arismendy
3rd Gear
Default DIC trouble code 1217 cleared & fixed!
so after much debate on fixing the C 1243 stalled pump & Abs Traction control service light I decide to flush the brake fluid and see what happens, then the C 1217 code shows up and the shop
cannot find the electrical problem from code C1217 so I read this forum follow all the instructions on here and check the Abs 40 Amp Maxi Fuse and it’s blown! Buy a new one and the problem is solved! No more Abs Traction control Active Handling lights! Yeeepeee! Thanks to all u guys who put ideas into this Kudos to you all!
Old Jul 25, 2020 | 11:55 AM
Joe Arismendy
3rd Gear
Have you checked the Maxi fuse 40 amps ABS? also read the post by pewter99 Admin. below was very helpful for me!
Old Sep 27, 2023 | 06:13 PM
Cherry3m's Avatar
Cherry3m
THANK YOU FOR THIS POST!!!
I had all but given up on my ABS/AH/TC on my 2000 vert. I exercised the pump for several times over a few hours, reassembled, cleared codes, removed window valet and the error codes persisted. Found this thread, and sure enough the 40 amp fuse was blown. Popped in a new one and I’m good to go. Took it out in the rain and commenced hard braking, donutting, and kicking out the rear end. Had a blast! And the ABS, AH, and TC kicked in as it should.
I’m super pumped! Drove around with those darn lights on for about a year.
My next move was pulling to dash lights just to get rid of them.
Thanks so much. I freaking love this forum.
To error code c1217
