Limited slip additive...
Old Aug 2, 2017 | 06:59 PM
Oville08c6's Avatar
Oville08c6
Default Limited slip additive...
Do you or can you use limited slip lock with Amisol Severe Duty 75-90W ??
Thx!
Old Aug 2, 2017 | 09:28 PM
chain_5001's Avatar
chain_5001
Amsoil recommend adding if you get chatter in your differential.
Old Aug 2, 2017 | 10:45 PM
StingrayRebel's Avatar
StingrayRebel
I've used amsoil severe gear since I bought my car, never used any additive and never had an issue... try it without and if you hear noise add a little at a time... you don't want too much additive in there or it could cause the clutches to slip when they shouldn't be slipping
Old Aug 3, 2017 | 08:11 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Aug 3, 2017 | 09:37 AM
jjc508520's Avatar
jjc508520
After buying the GM additive I read on the bottles that most have it included already - but that adding more won't hurt....
Old Aug 3, 2017 | 09:41 AM
chain_5001's Avatar
chain_5001
Yes, you can buy gear oil with limited slip additive already added. Most guys like to use gear oil without it so they can add the amount that works best for their application.
Old Aug 3, 2017 | 11:02 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
DO NOT ADD MORE THAN THE differential wants!! IN THIS CASE MORE IS NOT BETTER.
Most people use a GL-5 lube with the additive already in it. If you do some very tight figure eight turns in an empty parking lot and you don't get any limited clutch chatter,,, LEAVE WELL ENOUGH ALONE!
If you get differential limited slip clutch chatter, add just a LITLE more of the additive and go back out and test.
To Limited slip additive...
