So I purchased a 2001 corvette auto. I get no clicks when attempting to start engine. Fuel pump primes. I jumped the TDR relay and it cranked. No voltage at starter when key is turned over fully. brand new battery. Cleaned grounds. I think it might be the BCM. Security light goes out before attempting to start. Any help is greatly appreciated. I am planning on using this corvette as a donor for my 1940 nash lafayette. Thanks
I tried to use the built in code reader but the buttons do not work on the cluster . this car has almost everything gone and sold (ie air bags doors etc)
Maybe I should look into getting the buttons to work?
Does the engine need the bcm to run.... as in.. can I bypass the bcm completely?
when I get it to crank, It does fire and run for a half second because of primed fuel system. but it dies right away ... fuel pump is not running when jumping the purple wire to the red
