Tire psi
Old Aug 24, 2017 | 03:25 PM
Paininthebutt's Avatar
Paininthebutt
2nd Gear
Default Tire psi
My issue is that I want to put 45 psi in my tire but it causes the message and warning to come on. Is there something I can reprogram where it won't give a warning until it drops below 45 psi?
Old Aug 24, 2017 | 04:16 PM
coia96vette's Avatar
coia96vette
Why would you want to put 45 psi in the tires when the car is designed for 30 psi? Just curious as for why.
Old Aug 24, 2017 | 04:38 PM
Skyhawk23's Avatar
Skyhawk23
Old Aug 24, 2017 | 04:45 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by 8VETTE7
............Why on earth do you need 45 lbs tire pressure???
Well, his/her user name is "paininthebutt".............45 pounds of air in the tires will certainly give you that!!
Old Aug 24, 2017 | 04:53 PM
FX VETTE's Avatar
FX VETTE
Old Aug 24, 2017 | 04:55 PM
pjdbm's Avatar
pjdbm
45 will easily be 48 On some hot roads too
Old Aug 24, 2017 | 07:34 PM
StingrayRebel's Avatar
StingrayRebel
doesn't care about traction, uneven/premature wear, or even tire failure would be my best guess... the op could have the tpms turned off with a tech2, I don't have issues with that personally but I do not recommend running the tires at that high of a pressure
Old Aug 24, 2017 | 08:39 PM
DVUSz06's Avatar
DVUSz06
So many people look at the side of a tire and it will have a "max pressure 45" and think thats what you should air to, but that is a safety warning.
There is a sticker from the manufacturer on most vechicles that has a recommended tire pressure Thats what you should run, or at the very least a starting point, those recommendations are based on tire size and weight of the vechicle. Not saying it can't be tweeked a little but an additional 50% psi over vechicle recommendation is just crazy, and a recipe for disaster.
Old Aug 24, 2017 | 09:23 PM
lionelhutz's Avatar
lionelhutz
Start with the door sticker pressure and tweak from there.
For example, I run a little lower because I have wider and lower profile tires compared to stock. I wore the previous PS2's completely flat and got a LOT of miles out of them so tweaking the pressure to match the tires has worked well for me.
Old Aug 24, 2017 | 11:05 PM
Paininthebutt
2nd Gear
I have a 98 C5 and I'm running after market tires that require a minimum of 40 psi.
Old Aug 24, 2017 | 11:13 PM
MSUGTO's Avatar
MSUGTO
What size of tire are you running?
Old Aug 24, 2017 | 11:53 PM
GTs 58's Avatar
GTs 58
My 1/2 TON truck specs say 39 PSI and the 02 Z is 30 PSI. The 3/4 ton Ford was 45 PSI. Guess if your going to haul 800 lbs. of sand in the trunk I'd pump em up a bit. In all my years I've never seen a factory spec over 32 psi on a car.
Old Aug 25, 2017 | 01:25 AM
grantv's Avatar
grantv
Don't think I've ever seen a tire state minimum pressure TBH. But I really don't look at every tire. What tire? Sure that doesn't state max?
Old Aug 25, 2017 | 07:34 AM
leadfoot4's Avatar
leadfoot4
Originally Posted by GTs 58
.... In all my years I've never seen a factory spec over 32 psi on a car.
The only factory recommendation over 32 PSI, that I've ever seen, in a passenger car/SUV, is my roughly 5000 pound Jeep Grand Cherokee. The recommendation for it is 33 PSI.
Old Aug 25, 2017 | 10:29 AM
My 2015 Impala has a tire pressure recommendation of 33 psi and I've had several other cars that recommend that or higher tire pressures.
That said, I'd be curious what tires the OP has that says to run a minimum of 40 psi in them.
Old Aug 25, 2017 | 10:19 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
...might be some new age tires...maybe space shuttle tires?
Old Aug 25, 2017 | 10:43 PM
fuggles's Avatar
fuggles
If you look at tire pressure recommendations the tire manufacturer always states that you should check with the vehicle manufacturer for recommended tire pressures. This is because tire pressure requirements are based on vehicle weight. So your statement that the tire manufacturer requires 40psi makes no sense. This is contradictory.
To Tire psi
Old Aug 25, 2017 | 11:26 PM
GTs 58's Avatar
GTs 58
Lost some air. The OP said 45 psi.
Old Aug 26, 2017 | 08:24 AM
leadfoot4's Avatar
leadfoot4
Wonder what happened to the OP??
Old Aug 26, 2017 | 05:57 PM
jcgunn's Avatar
jcgunn
Maybe the OP is worried about hydroplaning. The minimum speed for hydroplaning (in knots) is nine times the square root of the tire pressure (in PSI) so a 30 PSI tire will hydroplane at 49 knots (56 mph), but his minimum req'd 45 PSI tires hydroplane at 60 knots (69 mph)
Just my thoughts...
