Tire psi
Old Aug 26, 2017 | 07:01 PM
iced's Avatar
iced
i wouldn't go over 35-36 psi.
Old Aug 26, 2017 | 08:04 PM
GTs 58's Avatar
GTs 58
I'd stay with the tires suggested pressure. ...
Old Sep 5, 2017 | 07:45 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Yello95
one of his tires blew and shot him into outer space
indeed!!!
Old Sep 7, 2017 | 09:35 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Originally Posted by Paininthebutt
I have a 98 C5 and I'm running after market tires that require a minimum of 40 psi.
and what tires are these? where did you read that at?
Old Sep 7, 2017 | 09:41 PM
iced's Avatar
iced
Might be XL tires that hold a max of 51-54 PSI?
Old Sep 7, 2017 | 10:11 PM
StingrayRebel's Avatar
StingrayRebel
op was probably thinking minimum when it was actually maximum
Old Sep 7, 2017 | 10:37 PM
iced's Avatar
iced
Originally Posted by 8VETTE7
Nope....
There is NO TIRE manufacturer that will state a pressure to put in the tire (other than a MAX design pressure for the tire). Go to any tire manufacturer web site and they will refer you to the car manufacturer sticker on the vehicle door. Tires are not manufactured for a specific car and therefore the tire manufacturer does NOT know the application/load the tire will be used on. Hence they refer you to the car manufacturer specified pressure usually on a sticker on the drivers door.
Yup, based on car weight and wheel.
I was just thinking if OP had XL tires and thought he can put 40 psi in there without bursting the tire lol
Old Sep 8, 2017 | 08:08 AM
leadfoot4's Avatar
leadfoot4
This HAS to be a "troll topic". The OP put up 2 posts, both on this thread, on the same day, and has never come back.....
