Cruise Control drops out
Old Aug 27, 2017 | 11:05 AM
Grandpa1's Avatar
Grandpa1
Default Cruise Control drops out
On my 2003 Vert (automatic) I can be cruising along at speed and the cruise control drops out. I can re-set it no problem. It's not all the time but it does happen.
Any ideas of what's going on?
Old Aug 27, 2017 | 11:49 AM
Grandpa1's Avatar
Grandpa1
Originally Posted by 8VETTE7
See above in RED.
No. I will see if there are any codes.
Thanks!
Old Aug 27, 2017 | 01:40 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
This may help as well>
https://www.corvetteforum.com/forums...djustment.html
Old Aug 28, 2017 | 03:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
See above in RED.
Have you pulled codes to see if there is any info stored that may narrow down the cause??? Several possible PCM codes related CC.
Possibly an improperly adjusted brake switch that causes the CC system to think the brake was depressed on a rough road.
EXACTLY!
Old Aug 31, 2017 | 06:19 PM
jjaaam's Avatar
jjaaam
See above in RED.
I had the exact same problem on my Tahoe. Brake pedal switch was bad. $20 part and it was fixed.
That being said...I would think it's a lot easier to twist your body up to get to the switch on a Tahoe than on a C5!
Old Sep 1, 2017 | 06:42 AM
Spaceme1117's Avatar
Spaceme1117
I would also check to see if your third brake light may be burnt out. Had the exact same thing happen to me on a 2006 Grand Prix GXP. Sure enough it was a third brake light burnt out. Not sure why GM put the cruise control and third brake light on the same circuit but this is common on many GM cars.
To Cruise Control drops out
