98 fuel pump (return line)
Old Aug 30, 2017 | 05:08 PM
Rob Petyo's Avatar
Rob Petyo
Default 98 fuel pump (return line)
Can someone help me identify which line is the return on the fuel pump? From what I saw in the book, it looked like it was the middle line. I want to drain the tank and was told to disconnect the return line to drain it. Thanks.
Old Aug 31, 2017 | 10:39 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just go to the drivers side fuel RAIL and on the front of that rail is a Schrader valve. Remove the small valve from the inside of that fitting (with a tire valve tool) and run a line from the fitting to a gas can.
Remove the fuel pump relay and jumper the hot and pump 12+ pins to run the tank pump.
Old Aug 31, 2017 | 02:27 PM
romandian's Avatar
romandian
if its like on a 99, then the small line (5/16) is the return line. the bottom (black) line is from the pump and i would use that. or, even simpler, disconnect the braided line at the firewall and put a hose on the male nipple.
Old Sep 2, 2017 | 08:21 AM
Rob Petyo's Avatar
Rob Petyo
Thanks for the replies! I ended up draining from the top line. I have FAST fuel rails and did not have much gas pressure coming from the rail when I disconnected it. that is why I drained the tank.
A new lingenfelter fuel pump is going in (P/N L71065197_
To 98 fuel pump (return line)
