4l60e noise from N to D
Old Aug 31, 2017 | 09:49 AM
RickyCorvette90's Avatar
RickyCorvette90
Default 4l60e noise from N to D
Hi guys!
Just rebuild my 4l60e and also added a trans go shift kit.
No problem shifting manual but from N to D it make this noise.
Any ideas??
Thanks to all will decide to help me.
Greetings from Italy
Riccardo
Old Aug 31, 2017 | 10:45 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by RickyCorvette90
Hi guys!
Any ideas??
https://www.youtube.com/watch?v=QMxOCPZDwqo
Riccardo
Riccardo
That sounds like an APPLY SERVO O ring squeal. That servo applies the force to one of the drum bands when you shift to Drive.
As long as it working fine, I wouldn't be to concerned. It might make less noise over time after it wears in.
Are you POSITIVE that you properly filled the trans????? Did you open the fill port with the engine RUNNING and trans fully warm and add fluid?
Bill
Old Sep 1, 2017 | 08:42 AM
RickyCorvette90
Originally Posted by Bill Curlee
Riccardo
Bill
Thank's Mr.Bill!
Positive at all!!!
Another problem that happen is a slippage, when i drive in D and it put the 3rd gear from 2700 rpm to 3500-4000rpm at 50% accelerator.Also on lower rpm the lock up set in really late.
Is possible a bad stall converter?Possible that the stock stall converter soffer the shift kit?it's really faster than stock.
I'm going to make some video that will help you or somebody else to understand better.
Old Sep 1, 2017 | 10:40 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have slippage,,,,,,,,,,,, that needs to be addressed ASAP!!! Slippage can be caused by a number of issues BUT, seeing that you have noise when that servo operates, I would start by inspecting that.
If I'm not mistaken, you can access and inspect that servo easily. Pop it out and see if you have damaged seals or a damaged piston.
Slippage will burn up those bands very quickly.
Bill
Old Sep 1, 2017 | 02:15 PM
RickyCorvette90
Bill
Mr.Bill,
watch it please.
Riccardo
To 4l60e noise from N to D
