Tac issue
Old Sep 4, 2017 | 07:57 PM
Vett4MVZ's Avatar
Vett4MVZ
Default Tac issue
2000 C5. On way home from a club run last Saturday my tac started to bounce from 0 to 2500 rpm. Some times it would just be 0 and the HUD was fluctuating the same. Other times it was reading normally on gage and HUD
Any idea where to start looking
MVZ
Old Sep 5, 2017 | 04:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
MVZ
IF,,,,,,,,,,,,,,,,,, the ONLY thing that was having issues was the TAC, then I would say it is IPC and or PCM related.
Here is a schematic for the IPC/TAC As you can see it is NOT connected directly to any sensor. The signals come from the class 2 serial data buss.
Do you do any PCM Tuning or used any tuning software recently?
You could have a corrupted serial data circuit.
Pull your DTCs using the DIC and list what appears.. If there are a TON of DTCs, clear them all and them report what comes back.
Old Sep 5, 2017 | 07:37 PM
Vett4MVZ's Avatar
Vett4MVZ
Thanks Bill. Here are some DTC's that are listed
PCM P0654
AO LDCM B2252H
LDCM B2284H
Old Sep 7, 2017 | 01:48 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PCM P0654
AO LDCM B2252H
LDCM B2284H
PCM P0654 Engine Speed Output Circuit.
The LDCM B2284H tells me that you are having an issue with low battery power some time during an ignition ON period. If it were ME, I would have the battery tested. You can try to fully charge the battery and then CLEAR ALL THE DTCs and see where you are at.
The C5 DOES NOT like low battery power.
Are you sure that you read the LDCM B2252H correctly?
Bill
To Tac issue
