Medium Brake Kit
Old Sep 6, 2017 | 08:34 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Default Medium Brake Kit
seeing as a big brake kit costs upward of 3000.00 and moving to c6 z06 brakes is about 1200.00, i decided to go with the, what i dub, the medium brake kit. others have done this. you take front brake calipers and rotors and install on the rear. you do lose the ebrake with this. most threads i have read on this have been outdated and most pictures lost in the process.
so here's my documentation. lucky for me, i still have my rear c5 suspension parts laying around. first thing i read was the bracket will hit the ebrake backing plate. it does by about 1/4". so you can grind the bracket down to clear it, or just push it into place, slightly bending the backing plate. here are pictures of that.
in the third picture, you can see there is plenty of room to grind the bracket down without interfering with the bolt depth.
Old Sep 6, 2017 | 08:35 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
now, for those wanting to keep the ebrake, you can use rear rotors and front brackets from a c6 z51. there is a little work needing to be done. with the thinner rotor of the z51, you have to do a couple things to prevent the inner pad from slipping out of the bracket.
https://www.corvetteforum.com/forums...post1585471818
SacCityCorvette
I use C6 z51 rear rotors to retain the E Brake. Because the rotors are thinner compared to the front C5 rotors, I had to add a piece of .250" plate to the bracket. See pics. If you don't, when the pad gets about halfway worn down it will slip between the rotor and bracket. NOT GOOD! And DANGEROUS!
Old Sep 6, 2017 | 08:37 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
My brake rotors and pads arrived today. Power stop. So far I'm about 225.00 into this.
Old Sep 6, 2017 | 08:39 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
mock up of the rotor and caliper. tiny scrub noise coming from the backing plate without the caliper bracket on. very minor due to the angle of the rotor center section.
Old Sep 6, 2017 | 08:40 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
calipers painted and cleared by my friend at law dawg restorations
Old Sep 6, 2017 | 08:41 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
in preparation for the hurricane, i finally put the brakes on.
i already had braided brake lines. i knew ahead of time, they might be short. one person bought 2" longer stock rubber lines from NAPA. i relocated the mount down a couple inches and fixed the length/suspension travel issue.
Old Sep 6, 2017 | 08:43 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
some pictures of the rotor differences
Old Sep 7, 2017 | 08:23 AM
a_ahmed's Avatar
a_ahmed
so there is no way to retain e-brake?
Old Sep 7, 2017 | 10:50 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Some have C6 Z51 rear rotors and C5/6 2 piston PBR front caliper to retain the e-brake
https://www.corvetteforum.com/forums...in-rear-4.html
I would upgrade the front before the rears.
Old Sep 7, 2017 | 11:23 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
I guess you missed post #2 where it goes through what you need to do to retain ebrake?
To Medium Brake Kit
