2000 moves then quits
Old Sep 7, 2017 | 05:16 PM
acorvetkid's Avatar
acorvetkid
Default 2000 moves then quits
Hello everyone, my 2000 vet with 33k miles I bought new just started having problem. starts rite up then after it goes about 10 feet dies...it will start rite back up but continues to do this. I had a dealer recall in 05 and they removed the steering column lock plate . it is an automatic... I had the dealer test the keys and said they are fine, I charged the battery and still quits... after I put the key in and start it the security light goes out, then the dash says remove key and wait ten seconds, then says service steering column lock, then service traction system, then service abs. I heard theres a reset switch somewhere ? Any ideas ?
Old Sep 7, 2017 | 05:35 PM
Smoken1's Avatar
Smoken1
This is what you need
http://complianceparts.com/lmc5description.html
Old Sep 7, 2017 | 08:06 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Agree with the others and I have the LMC5 as well. In the mean time, take the battery cables off, clean them and torque them properly. Sounds silly, but this can be a solution for some. Still do the LMC5 either way as it is a great long term solution.
Old Sep 7, 2017 | 09:35 PM
acorvetkid's Avatar
acorvetkid
Thanks everyone... Sounds great . im not that good with car electrical systems is this fairly simple ?
Old Sep 8, 2017 | 12:50 AM
CactusCat's Avatar
CactusCat
Yes, the LMC5 is very easy to install, has good instructions with it, and if you happen to run into any issues, Richard at Compliance Parts is one of the finest people to deal with that you'll ever meet. Also, yes, the battery issues are easy but if you're not comfortable with any of this, find a competent friend or mechanic. Both are easy jobs.
Old Sep 8, 2017 | 08:25 AM
am3gross's Avatar
am3gross
here is a video to build your confidence, it looks pretty simple and straight forward. hope this helps.
Old Sep 24, 2017 | 08:04 PM
acorvetkid's Avatar
acorvetkid
Thank's everyone . Pretty easy to install and works great... Thanks so much for all the help...
Old Sep 24, 2017 | 08:16 PM
am3gross's Avatar
am3gross
glad you got it straight! now post some pictures! we love that car ****!
To 2000 moves then quits
