Stabilizer bar end link going bad?
Old Sep 18, 2017 | 09:46 PM
bwill03z's Avatar
bwill03z
Default Stabilizer bar end link going bad?
When I'm turning at low speeds, like in a parking lot, and on a bumpy or uneven road I feel through the steering something loose in the front end. I don't hear any metal on metal or knocking sounds I can just feel it in the wheel that something seems to be a little loose. It's when I'm turning right btw. Is a stabilizer bar end link a likely culprit?
Old Sep 18, 2017 | 10:40 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
what year ??? the early models had plastic end links and will break !!!!!
Old Sep 18, 2017 | 10:51 PM
bwill03z's Avatar
bwill03z
2003. They are the aluminum ones
Old Sep 19, 2017 | 08:10 AM
strand rider's Avatar
strand rider
I would like to help, but can only think that the stuff you feel at low speed, would not be fun at high speed. Right front always gets it, the gutter track puts on extra wear.
Old Sep 19, 2017 | 08:40 AM
ArtClassShank's Avatar
ArtClassShank
Endlinks are a consideration. Examined my front recently, torn boots on either side. Not much grease left, got a kinda clinky sound over rough pavement at loud speeds. Couple of MOOG endlink replacements and it's gone. Also greased the leaf spring bushings a little bit. Bushings there also take a beating.
Old Sep 19, 2017 | 11:25 AM
twokbolt's Avatar
twokbolt
Check your tie rod ends and wheel bearings as well.
Old Sep 21, 2017 | 07:45 PM
My Vette Life's Avatar
My Vette Life
just change them. chances are its bad.
Old Sep 24, 2017 | 11:05 AM
onspeed's Avatar
onspeed
Aluminum ones can still break at the ball joint
Old Sep 27, 2017 | 09:12 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I doubt it is the sway bar end links.
When they are bad they usually just make some noise, and if really bad, broken, or missing they will allow more body lean.
However, they shouldn't make the steering feel loose, especially at low speeds where they are not really controlling body lean.
If you are feeling something loose in the steering it is probably something in the steering or suspension like tie rod ends, steering rack, bad bushings, ball joints, etc.
Good luck.
To Stabilizer bar end link going bad?
