Exhaust question 2002 hatchback
Old Sep 20, 2017 | 09:18 AM
fvracerone1's Avatar
fvracerone1
8th Gear
Default Exhaust question 2002 hatchback
I am in the process of removing my stock C5 after/ converter system with a Borla Singer 2 outlet (not 4) system. Was considering replacing the X pipe. Is there a considerable horsepower/noise gain?
Frank
Old Sep 20, 2017 | 11:34 AM
grantv's Avatar
grantv
The X might even reduce the noise level a bit. Noticeable HP increase? No.
Edit; I'd still always recommend an X for what 8vette7 said.
Old Sep 20, 2017 | 01:25 PM
knewblewkorvette's Avatar
knewblewkorvette
Originally Posted by 8VETTE7
Don't expect any horsepower you can feel from an X-pipe.
I found that all it did was help reduce the motor boat sound on decel.
I put on a Magnaflow X-pipe, was supposed to add like 5 HP but yeah, who knows about that. It did kill the motor boat sound which I actually liked.
Old Sep 20, 2017 | 02:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If we got all the power each modification manufacture promised from using their product, we would not be able to drive our cars on the street!
I It will change the exhaust note and reduce the motorboat sound but, don't hold your breath on any added HP.
Check this out!!
If doing this to a set of headers doesn't kill power, adding a single X pipe sure wont!!!!
I found this AMAZING!
HA!!! Here is an X Pipe, H Pipe and NO crossover test!
BC
Old Sep 20, 2017 | 02:57 PM
You won't see any HP gains, but the exhaust note should be better and if the mufflers produced any drone, the X-pipe should help with that.
Old Sep 20, 2017 | 03:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its very SAD!
Everyone talks about and compares the X pipe to the H pipe but NO ONE ever considers the O Pipe.
I bet that sucker will add some power!!!!
BC
To Exhaust question 2002 hatchback
