C5 (2002) intermittent starting
Old Sep 20, 2017 | 02:16 PM
Lauri Griebel's Avatar
Lauri Griebel
1st Gear
Default C5 (2002) intermittent starting
hello I have a 2002 c5 corvette that won't start intermittently. I have all power, battery is good, dash lights up, by car just won't start. I can goes days with it having no issues starting and then all of sudden it won't start again randomly. I have had it looked at by 2 mechanics & the dealership and the car never acts up when they have it and they are unable to dublicate the problem. Car is also not throwing any codes. Does anyone have any ideas what this problem could be?
Old Sep 20, 2017 | 02:56 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Lauri, welcome to the forum!
You question will get many more replies if you post in the C5 section. Good Luck!
Old Sep 20, 2017 | 02:57 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF! C5 section is where you want to ask that question.
Old Sep 20, 2017 | 04:02 PM
Moving to C5 Tech.
Old Sep 20, 2017 | 04:29 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, Lauri!
Bill Curlee posted a couple of responses in January 2011 that might address your issue. Good Luck:
"Most of the time this issue happens, its the fault of the stater solenoid. They are known to fail and cause this issue. Happened to my 02 ZO6. I just changed the solenoid and problem was solved. If you tap the starter and the car cranks, thats proof positive the solenoid is hosed
It can be caused by other components but, instead of throwing cash and parts at the issue, its best to use a volt meter and figure out if your getting 12 VDC to the solenoid and if your not, figure out whats not allowing it to get there. Heres a schematic that has all the components involved in starting your engine:
The THEFT DETERRENT RELAY is a good place to start testing. The purple solenoid wire should have 12 VDC on it when you crank the engine."
"READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!"
Old Sep 20, 2017 | 04:51 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP!! MOST,,,,,,,,,,,,,,,,,,,,,,,,,,,,, of the time, it a problem with the starter solenoid.
You can spend a LOT of money just going that route and still not solve the issue.
You really need to carefully examine the issue and use the schematic and a meter to troubleshoot.
You can always do the starter THUMP test!
Have someone HOLD the key to START and when it is sitting there not cranking, THUMP the starter. If it comes to life, its the solenoid or a bad connection on the solenoid.
BC
To C5 (2002) intermittent starting
