P2066, opinions on replacing pumps
Old Sep 20, 2017 | 01:53 PM
ascastil's Avatar
ascastil
Default P2066, opinions on replacing pumps
Im getting the fuel gauge showing empty and code 2066. I know there is the Techron treatment and new level sensors. Im going to be replacing my hacked stock driver pump to a new GM unit and ECS fuel system to feed the superchager already on there. Should I just go ahead and install a complete new pump on the passenger side instead of just the sensor? Ive torn this car apart too many times and as the saying goes "while youre in there"......... I think I know the answer, replace it. Does the passenger pump ever get tired? Cars an 04 with 110k miles.
Old Sep 20, 2017 | 02:34 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The passengers tank DOES NOT have a pump.
It has a SYPHON JET that uses a small stream of fuel (supplied by the drivers side pump) to squirt into a venturi tube which causes fuel to flow from the passengers side to transfer into the drivers tank.
SO, you could make sure that there isn't any debris in that tank and the venturi is clean and able to flow fuel.
Old Sep 20, 2017 | 07:00 PM
ascastil's Avatar
ascastil
Ya I know that thanks. Does it ever fail? Id hate to replace the sensor and the following week the SYPHON JET fail or something and Id have to pull the tank again.
Old Sep 20, 2017 | 11:06 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any trash or bits inside either tank can clog an old and or new syphon pump. SO,,, Clean the tanks out well..
BC
To P2066, opinions on replacing pumps
