A/C drain hose
Old Sep 24, 2017 | 05:04 PM
crazybird's Avatar
crazybird
Default A/C drain hose
With the heat today I ran my a/c a lot I noticed some water dripping into the passenger foot well. After about 45min of driving it was a lot of water leaking inside, like it would pour out in a corner.
I found a thread on C3's with the same issue and its the drain hose from the evaporator being clogged.
Anyone experience this with their C5?
Old Sep 24, 2017 | 09:33 PM
crazybird's Avatar
crazybird
Perfect!
Thank you.
Old Sep 25, 2017 | 11:19 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look for the 90 Deg Rubber fitting directly aft of the passengers head.
It looks like this:
Its probably full of crap or a snot like substance. If you pop it off the fitting on the fire wall, condensate should pour out if it is indeed plugged..
MAKE SURE that your BCM is dry or you will have all sorts of crazy electrical issues!!!
Old Sep 29, 2017 | 07:48 PM
crazybird's Avatar
crazybird
I'm pretty sure I can see the fitting but getting my gorilla hands on it from above seems impossible. lol
Is it easier to get at from below?
Old Sep 29, 2017 | 07:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Absoluty!!!!! No chance from the top
Old Oct 2, 2017 | 12:34 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
How do you remove it? Do you just pull it out or have to turn it? Thanks.
Old Oct 2, 2017 | 12:45 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! From under the car. It just slides on. May be stuck from crud.
If you have headers,,,,,,,,,,,,,,,,,,,,, GOOD LUCK. Long Screwdriver? Hire a little Kid...
Old Oct 3, 2017 | 12:30 AM
laurent_zo6
Thanks. Guess I should have been clearer. By turning, I mean unscrew it.
Old Oct 3, 2017 | 03:00 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have actually been able to pop it OFF from the top. I used a LONG skinny flat blade screwdriver and worked it off the nipple.
You WILL NOT, be able to put it back ON from the TOP!
You can JUST see it in this photo below and aft of the main wiring harness loom:
To A/C drain hose
