2001 C5 part time idle problem
Old Sep 27, 2017 | 12:13 AM
wburner71's Avatar
wburner71
8th Gear
Default 2001 C5 part time idle problem
Hello CF members,
Your help is much needed as I'm at a loss right now. I have recently purchased a 2001 coupe with 42,000 miles. Car ran great for about 1 month and then all of the sudden I started getting a bad stumble in gear at a stop. Only at a stop or in park at idle. It will come and go and have researched forums til im blue. No lights or codes have came up. I first changed the MAF sensor and though I solved it and bam, back again. Changed all 4 O2 sensors and nothing. Came across a article about oil in the intake which I did verify that I have that problem. Removed the TB and did a good cleaning and symptom went away. 2 days later back again. Order a 140 oil catch can which I installed and still getting oil in the intake. I need some ideas here as im about ready to change plugs and wires as I have read issues regarding plug wires arching. Before I do i was hoping for some suggestions. Borla exhaust and the passenger side tail pipes have a lot of soot and barely any on the drivers side thus my reason for changing O2 sensors. I'm thinking the oil in the intake is the main issue but not sure where im still getting oil in the intake from. Any good ideas would be appreciated.
Old Sep 27, 2017 | 03:43 AM
oelarse's Avatar
oelarse
Maybe you have a vacuumleak somewhere in the intake or attached lines lines .
If the engine is getting extra (false) air not detected by the MAF it will
cause lean conditions at the O2 sensors . Then the ECM will add more fuel
to correct this . The fueltrim values will reflect this if you connect a scanner or a Tech 2 .
The vaccumports is on the rear side of the intake and goes to the MAP sensor , brakebooster and to the climate system and the air system . Please see this post for more photoes of theese lines
https://www.corvetteforum.com/forums...nge-vents.html
Check also if you a leak on the EVAP purge solonoid line located on the driver side head .
Old Sep 27, 2017 | 04:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WELL,,,,,,, The easiest route would have been to start at the plugs and wires.
If it were me, I would order some GM Performance Red Wires & OEM AC Delco plugs and install them.
Make sure that you use a small bit of antiseize on the plug threads and use dielectric grease on the plug boots to prevent them from sticking to the plugs and coil towers.
NO LIGHTS or CODES.... How are you reading the DTCs????? Are you using the DIC??
What lights? If you have a valid MISFIRE, it can and will cause the Check Engine Light to FLASH when the PCM is actually detecting the misfire condition.
DATA LOG THE PCM. You can use the DIC to read ALL the C5 DTC but you have to have a scanner that can read and displat LIVE SENSOR DATA to see what is really going on.
I recommend investing in a hand held scanner that has the ability to read all your Live Sensor Data and check LTFT, O2 Sensor data, etc......
BC
Old Sep 27, 2017 | 06:02 PM
wburner71's Avatar
wburner71
8th Gear
Checked for vacuum leaks and nothing. I would assume the vacuum leak would give me issues all the time.
Old Sep 27, 2017 | 06:21 PM
wburner71's Avatar
wburner71
8th Gear
Bill Curlee,
That's what I plan on next as it wont hurt to have new plugs and wires anyways. When this has happened I have checked the onboard DTC and hooked a scanner up which did not reveal any codes. No check engine light flash or anything and that is what has stumped me. What I have done today was disconnected the PCV line from the intake that comes from the catch can and routed the line down towards the ground. I capped of the fitting on the tb and then removed the tb and cleaned any oil that was collected. I have assembled back together and no issue as this morning on the way to work. If it comes back I will hook the scanner up and check what you said but I have replaced all 4 sensors and still does the same.
Old Sep 27, 2017 | 06:23 PM
wburner71's Avatar
wburner71
8th Gear
What about a ground issue? I have read that these cars have a ground issue as in the past I have read the DTC comes up with codes stating loss of comunication
Old Sep 27, 2017 | 06:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by wburner71
Hello CF members,
Lets address some of your concerns:
See my comments in blue
ONLY the 2 Primary O2 sensors have ANYTHING to do with engine management. The post CAT sensors are only there to monitor nd report emissions and cat status.
Its possible that the new O2 sensors are still NOT performing correctly. The scanner will tell you that.
ALL C5s have oil in the intakes. Yes a Catch can will help. Are you POSITIVE that ALL of your PCV pluming is sound and not broken (very common issue). Check the ability of ALL of the PCV tubing and fittings ability to hold vacuum The fittings behind the manifold are well known to crack and rot!!
Oil in the intake would effect BOTH banks. Its not bank selective. SOOTY one bank tells me that you have a BANK issue. Coil Packs, injetors etc.. There are two coil power bank fuses. They are IGNITION SWITCH POWERED. See what the voltage is on the fuse test slots on top of the fuse to chassis ground (ignition switch to ON) Should be full battery voltage.
On the back of the drivers cyl head is the coil pack ground. Check that ground and the two ground wires in the EYELET.
I'm thinking the oil in the intake is the main issue but not sure where im still getting oil in the intake from. Any good ideas would be appreciated.[/QUOTE]
IMHO, Oil in the intake is your least worries.
What does the IPC Volt meter on the IPC read when the engine acts up? You can also see that voltage in the DIC if you pull it up to monitor it.
Old Sep 27, 2017 | 06:57 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Which PCV system do you have on your engine??
Old Sep 28, 2017 | 01:12 AM
wburner71's Avatar
wburner71
8th Gear
Hello Bill,
A lot of great info. Sorry for the late response. I will check these tomorrow in the morning and respond. As foe the IPC it doesnt do anything when this happens and I have no IPC codes new or old. I will check the PCV line but im not sure how that would make it run bad as the line is simply a outlet for fumes. Both ends have a pcv valve on them which utilizes a one way check valve correct? I'm kinda starting to think your on the money with the passenger side bank issue. Today I ran with the pcv line disconnected from the TB and no change as it still stumbled for about 3 seconds. Just to clarify, No codes or check engine lights when this happens. As rough as it stumbles you would think some kind of fault code would appear. I did check the DIC onboard and the RDO brought up to history codes. u1000 and u1064
Old Sep 28, 2017 | 01:14 AM
wburner71's Avatar
wburner71
8th Gear
I have the top system that wraps around the back
Old Sep 28, 2017 | 01:21 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your engine tune is calibrated for that PCV system bypassing a metered amount of air around the throttle blade.
So, when you have a vacuum leak or the PCV leaks or you just VENT the system, the PCM has to make up for that added air by adding fuel via LTFT.
If you examine them, they will most likely be POSITIVE (shoule be near zero to slight negative)
Still, that would be a BOTH BANK issue. SO, take a look at SPARY and FUEL and all the things that make it happen for that bank.
Bill
Old Sep 28, 2017 | 01:43 AM
wburner71's Avatar
wburner71
8th Gear
This is what I'm reading right now. Below
Old Sep 28, 2017 | 02:52 AM
wburner71's Avatar
wburner71
8th Gear
I also have these items listed in red. Not sure what they mean at all. No codes though
Old Sep 28, 2017 | 08:41 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you have an owners manual for that scanner. Read it.
The EVAP means the emissions status for the fuel tank is not ready.
Not sure what the others in red mean without guessing
AIR could mean that the Air Injection Reaction (A.I.R. System) is not ready.
To 2001 C5 part time idle problem
