balancer
Old Oct 6, 2017 | 03:12 PM
namvet6869's Avatar
namvet6869
Default balancer
In process of installing new power bond balancer on my 2000. New balancer has a keyway. The crankshaft doesn't. How do I know which way it goes on. I kinda old school and thought all cranks had a keyway
Old Oct 6, 2017 | 03:14 PM
StingrayRebel's Avatar
StingrayRebel
just put it on, orientation doesn't matter... ls cranks don't have a keyway unless they are aftermarket
Old Oct 6, 2017 | 07:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! It doesnt matter BUT,, I have enough Mods that I wanter to be sure that the dampener did NOT rotate on the crank. I added a Pin in the dampner/crank to make ure that there was NO dampener rotation. I also used an ARP Bolt
Use the correct LS dampener bolt tightening procedure and you will be GOOD to GO!!! Get a good aftermarket dampener like the PowerBond.
Bill
Old Oct 7, 2017 | 08:09 AM
vettenuts's Avatar
vettenuts
I have the ATI and pinned it as well. One thing I did since the ATI has degree markings was to set the crank at TDC for #1 and then tried to align the zero degree mark on my damper as close to 12 o'clock as I could by eye. Helps with other tasks such as rocker installation, etc.
If the damper has a key, it lends itself very well to the ATI pin kit.
To balancer
