Oil Smells Like Gas
Old Oct 17, 2017 | 08:53 PM
MiniOctavious's Avatar
MiniOctavious
Default Oil Smells Like Gas
Hey y’all,
I have a 1999 Corvette 5.7.
Today while driving, I had a low oil level message come up on the dash. I stopped at AutoZone to grab oil to at least make it to the shop. I pulled the dip stick out to check the level and observed a little bit of white smoke coming from the stick. I then removed the oil reservoir cap and noticed a little more smoke. I could smell fuel on the oil cap and the rag I wiped the oil on. Needless to say it’s at the shop now, but was curious if anyone else has experienced this.
What is it?
Is it a common issue with this car?
is it expensive to fix?
Any information is appreciated!
Thank you ahead of time!
-Alex
Old Oct 17, 2017 | 09:01 PM
juanvaldez's Avatar
juanvaldez
I don't think that was a low oil level but low oil pressure. Gas in oil reduces viscosity. It will kill your bearing. Fuel can get into oil by things like stuck injector. You need to change oil before you run it anymore.
Old Oct 17, 2017 | 09:07 PM
MiniOctavious
The level was slightly low, but I didn’t think it was enough to make a light come on. The car has 72,000 miles. I just bought it about a month ago, so I’m fairly new to the car. If an injector is clogged does it need to be replaced, or does it just need to be flushed and an oil change.
Old Oct 17, 2017 | 09:11 PM
foggy's Avatar
foggy
change your oil and filter. Could just be condensation in oil...
short trips, or even not changing the oil enough will cause this.
You need to change your filters and fluids to get a baseline on your "new" car
NmtMev's Avatar
NmtMev
Ya... You need to take the lead shoes off. I bet if you drove it nice and easy most of the time your oil wouldn't have gasoline in it. Nothing wrong with the car. Just your driving habits.
Old Oct 17, 2017 | 09:12 PM
juanvaldez's Avatar
juanvaldez
Don't know about the source but gas in your oil is an engine killer. You need to have the oil changed right away. Then find out where the gas is coming from.
Old Oct 17, 2017 | 09:13 PM
MiniOctavious
As far as driving goes, I don’t not driving it hard. I will have the oil changed as well.
Thanks!
Old Oct 17, 2017 | 09:21 PM
NmtMev's Avatar
NmtMev
Thanks!
Send your old oil to Blackstone labs and get an OA. Take the sample mid stream. I usually have like 4% fuel in my oil. I beat on my car sometimes. Ask them to do fuel by gas chromatography. (GC fuel method) ICP results will tell you if you have ring wear which can contribute to your fuel dilution. Actually it will tell you a hell of a lot of things. I never used Blackstone before, but i did work in a private lab with the ability to test such things.
Old Oct 18, 2017 | 05:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BC
To Oil Smells Like Gas
