Horespower Numbers are Low
Old Oct 7, 2002 | 08:57 PM
dustyhuff's Avatar
dustyhuff
Default Horsepower Numbers are Low
I had heads/cam and exhaust installed on my 2002 coupe a month ago. We used a Comp cam and stock ported heads with FLP full exhaust. I gained 400.4 RWHP after the mods. I then installed LS1 Edit with 32lb injectors because the car was running lean. I only gained 8 more horespower by doing this. Do these numbers sound low?
[Modified by dustyhuff, 12:59 AM 10/8/2002]
Old Oct 7, 2002 | 09:04 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Horsepower Numbers are Low (dustyhuff)
may need more LS1edit work.
Old Oct 7, 2002 | 09:08 PM
C5Noir's Avatar
C5Noir
Man, I want your H/C if you gained 400.4 RWHP ontop of your stock setup ;)
It may need more tuning however, what are the cam specs and head flow #s?
Old Oct 7, 2002 | 09:12 PM
dustyhuff's Avatar
dustyhuff
Default Re: Horsepower Numbers are Low (C5Noir)
216 / 220 .525 / .532 114 lobe separation
I dont's know the specs on the heads. All I know is they are stock ported heads.
[Modified by dustyhuff, 1:13 AM 10/8/2002]
Old Oct 7, 2002 | 09:14 PM
C5Noir's Avatar
C5Noir
That's a pretty tame cam. Low lift and duration is not aggressive. Get a more aggressive cam and you'll get about 10-20 more RWHP. I suggest the TR224 ;)
Old Oct 7, 2002 | 09:15 PM
dustyhuff's Avatar
dustyhuff
I'm using the converters instead of the straight pipes. I've been told the straight pipes are good for an additional 10 RWHP. It's just to loud.
Old Oct 7, 2002 | 09:17 PM
dustyhuff's Avatar
dustyhuff
I'm sorry the cam specs are wrong, I don't no how to read!!
It's 269 / 273 .525 / .532 114
C5Noir's Avatar
C5Noir
10RWHP is a bit of a stretch but definately possible. Who suggested this cam?
Old Oct 7, 2002 | 09:18 PM
C5Noir's Avatar
C5Noir
Good lord, 269 and 273? Is that even possible? The lift is still really low though. Do you have any piston to valve contact?
Old Oct 7, 2002 | 09:23 PM
dustyhuff's Avatar
dustyhuff
Atlanta Chassis Dyno did the install. The cam was recommended by the installer. He said it was the biggest cam he could install, and still pass emissions. He dynoed a stock car with the same FLP exhaust and there was an 9.2 RWHP difference in the cats vs no cats.
Old Oct 7, 2002 | 09:29 PM
los7883's Avatar
los7883
Daannngggg....that's crazy...but .525/.532 sounds a bit weird...I have the TR 220/.561 in mine...can't imagine what the 269/273 would be like.
Old Oct 7, 2002 | 09:31 PM
C5Noir's Avatar
C5Noir
Some cars do well with no cats and some don't, just a chance you take. MTI uses cats on their 7.0L strokers b/c they get no significant gains w/out them.
Does these thing lope like a ****? I don't see how it's possible you have those durations.
Old Oct 7, 2002 | 09:35 PM
dustyhuff's Avatar
dustyhuff
I'm not very technical when it comes to cars my first # post might be correct. The car does shake a lot when idleing.
Old Oct 7, 2002 | 09:43 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Both sets of numbers are probably correct.
In the non LT1 or LS1 world people talk about cams in both Advertised Duration, and Duration @ 0.050. Thats why the second set of numbers posted are so much wider than the first.
For example, my T1 cam from MTI is 280/280 advertised but only 221/221 @ 0.050.
For most purposes the 0.050 numbers are the ones you really care about.
Eric
Old Oct 7, 2002 | 09:44 PM
Barely Legal's Avatar
Barely Legal
I used to have that cam. Nothing compared to a B1 or T1. When I did that and the CNC heads, I picked up like 25 RWHP. Just after the install I had a 250 lb friend with me on the test run. The car felt the same before it went in.
Switched to the T1 and gained a LOT of power.
Old Oct 7, 2002 | 09:47 PM
66ImpalaLT1
I hope you meant does NOT shake a lot. A cam with 114 lobe seperation angle shouldnt really have idle problems.
Eric
Old Oct 7, 2002 | 09:49 PM
dustyhuff's Avatar
dustyhuff
I'm planning on installing an NOS kit in the future. I've already purchased the kit from a friend that was used but cheap. He had it on an 2002 SS Camaro for about two months. The jets were installed in the air box. What is the best way to install the jets on a corvette?
To Horespower Numbers are Low
Old Oct 7, 2002 | 09:50 PM
dustyhuff's Avatar
dustyhuff
Default Re: Horsepower Numbers are Low (66ImpalaLT1)
I did, it has a little bit of a shake over stock.
Old Oct 7, 2002 | 10:01 PM
jmX's Avatar
jmX
As said above, he's quoting total duration numbers, not duration at 50 thousanths (like everybody else does). the 216/220 is what you want.
1) you using cats?
2) who's heads? the heads mean a lot. Bad heads = bad numbers. good heads = good numbers. specs, who ported them, flow numbers, etc all matter and you should know that kinda stuff
3) the cam is small, the lift is low. Go with a thunder racing 224 cam, or any other proven cam. You went small for good drivability, thats fine. Anything between 222-228 in duration with 550-570 lift on a 114 is probably about where you want to be
4) what RPM did your setup peak at?
5) automatic or manual tranny?
[Modified by jmX, 8:07 PM 10/7/2002]
Old Oct 7, 2002 | 10:06 PM
los7883's Avatar
los7883
Eric
I have a TR with a 114 LSA and it does shake a little bit when the RPM's get around 500 or so...had to raise the idle on mine...LGM and Speedtek were surprised the car was having that much of a problem idling with such a "mild" cam. Now have it set to 800 for idle and it's fine. Can't imagine what a 112 would feel like.
