I'm MN6 and plan to swap my broken stock 3.42 diff for the 3.15 diff from my spare c5 (who is an auto)
First, i pull the 3.15 diif, and we hurt the trans output shaft seal
So, i was looki,g for buy some seal, but as this seal (ref acdelco 24228816) is only for auto (and i will use the diff on my stick vette), does i simply have to remove this seal ?
Also, does i have to change the two rear axle seal (they seems to be good) or can i reinstall axle without new seal (ref is 88996703) ?
The seal/aluminum piece that says trans side in pic will not be used if going into manual transmission just remove it but you will need a new o ring seal where the trans mounts to diff
I will try to find them but i think my spare diff had new on them when i bye the entire spare car (and i use this car less than 1 year)
I have to check for having them faster as they purpose (as i live in europe, shop usualy speak about delivery between Nov. 6 and Nov. 10 and i will use them the 4 Nov
Also, they will cost 3 or 4x more (cause ship/fee/custom...)
And for upgrade, i plan to going C6Z gearbox/diff, this diff if just for putting back on the road asap ^^
