HUD Bench Test?
Old Nov 7, 2017 | 10:00 PM
Corvettes White's Avatar
Corvettes White
Default HUD Bench Test?
Question. Can the projector be illuminated in any way out of the car?
No chance anyone has a wiring diagram?
The vacuum fluorescent display has grown dimmer with time and am looking for a solution.
Thank you in advance.
George
Old Nov 9, 2017 | 10:16 PM
Corvettes White
Old Nov 10, 2017 | 02:05 AM
SilverC54me's Avatar
SilverC54me
The hud gets its data from the IPC. I don't think you can power it up by itself. You can bench test with an IPC, I have done this. You can see the display looking into the HUD from the top at just the right angle.
Vacuum florescent display will get dim over time with use. The only solution I know of is replacing the display element. I don't think you will find these separately however.
Gary
To HUD Bench Test?
