engine mount replace
Old Nov 9, 2017 | 12:35 PM
bobace's Avatar
bobace
5th Gear
Default engine mount replace
2001 c5 corvette oil pan setting on front leaf spring.
Noticed while servicing that the front of oil pan is seating on the front leaf spring. I am pretty sure this is not the norm. Cant find any information on this, need to know if anyone has replaced engine mounts on a c5.
Old Nov 9, 2017 | 04:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No, it not normal. Just unbolt the mount and jack up one side of the engine at a time and replace the mount.
Pretty simple.
Be careful not to squash the intake manifold into the fire wall and break it.
Old Nov 10, 2017 | 12:55 PM
SaberD's Avatar
SaberD
I know mine touches the oil pan with the front control arms disconnected, but I have the 3/8" lower hinson poly mounts. It might even touch with the control arms connected and the suspension unloaded when off the ground, but I can't say for sure.
Was the suspension loaded or unloaded when you noticed this? (ie was the suspension hanging?)
edit: I also have a z06 front spring.
Old Nov 10, 2017 | 01:01 PM
bobace's Avatar
bobace
5th Gear
Car was on stands with tires and wheels removed. Thanks
To engine mount replace
