bcn
Old Nov 9, 2017 | 01:19 PM
wellsy6's Avatar
wellsy6
1st Gear
Default bcn
when replacing the body control module does it need to be programed or is it plug and play
Old Nov 9, 2017 | 01:46 PM
Smoken1's Avatar
Smoken1
You need a Tech 2 to do it. Read thru this thread especially post 8
https://www.corvetteforum.com/forums...m-tcs-etc.html
Old Nov 9, 2017 | 01:48 PM
Smoken1's Avatar
Smoken1
Originally Posted by 8VETTE7
Needs to be programmed to the RPO's on your car.
Man you type fast...
Old Nov 9, 2017 | 04:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It is NOT a plug and play! There is an EMERGENCY SYNC procedure that will allow you to replace the BCM (say if you were stranded on the road)
1. Turn on the key for 11 minutes.
2 Turn off the key for 30 seconds.
3. Repeat 1&2 two more times.
4. Turn on the key for 30 seconds.
It will NOT have any factory options available but it will allow you to drive the car:
Check out this post for all the details:
https://www.corvetteforum.com/forums...m-program.html
Old Nov 9, 2017 | 04:30 PM
Smoken1's Avatar
Smoken1
Thats a better thread
Thanks, Bill
Old Nov 10, 2017 | 04:50 PM
SG Lou's Avatar
SG Lou
Seems like 8VETTE7 always beats me to the answer
To bcn
