Wheel sensor codes after tire replacement
Old Nov 10, 2017 | 09:36 PM
Torauma's Avatar
Torauma
8th Gear
Default Wheel sensor codes after tire replacement
I had a nail in my right rear tire so I took it to a local les schwab to get it patched. They gave me the keys after they fixed my tire and when I started my car I got a ABS light and traction control light on that was not present when I dropped it off. They brought it back into there shop to see if they damaged somthing but it all checked out and they could not fix the issue. The car now has c1232,c1233,c1234,c1235,c1255 codes that will not go away when trying to reset them any ideas on what could have happend or what they could have damaged? It drives fine just has the codes. It is a 2000 and has the f45 shocks if that makes a difference
Old Nov 10, 2017 | 11:55 PM
Moved to C5 Tech.
Old Nov 11, 2017 | 02:07 AM
Torauma's Avatar
Torauma
8th Gear
Originally Posted by 8VETTE7
C1255 is the code of significance here. It is telling you an EBCM Internal Error has occurred. I would have little reason to believe any of the other codes based on the C1255 being present.
I have seen this code caused by a low/bad battery, and also because of a bad ground. Of course it could also be a real internal failure of the EBCM.
I would start with having the battery fully charged and then load tested. A good battery at full charge will measure 12.7 to 12.9 volts or more measured across the battery posts with no load on the battery.
You can also check ground G103 . Here are a couple of links that should help you with C5 grounds:
http://forums.corvetteforum.com/c5-t...locations.html
http://forums.corvetteforum.com/c5-t...tion-long.html Post #1
thank you for your help! I will check the g103 ground for corossion and the battery. I find it very strange it happend after the tire service though I hope the tech didn't Jack the car up wrong and broke somthin but this is a good place to start.
Old Nov 11, 2017 | 07:53 AM
vettenuts's Avatar
vettenuts
Wonder if they were listening to your radio while they worked
Old Nov 20, 2017 | 06:45 PM
Torauma's Avatar
Torauma
8th Gear
(Update) checked the ground wires all looked pretty clean. checked the battery it was very low so I had it replaced. Abs and traction control light are still on, now im also getting a C0710 code active handiling code that goes away when cleared but pops back up shortly after any other ideas anyone Before I start throwing tons of money at the old girl?
To Wheel sensor codes after tire replacement
