Column Lock, ARGH!
Old Oct 9, 2002 | 01:20 AM
deeb0's Avatar
deeb0
Default Column Lock, ARGH!
After bleeding my brakes tonight, when i went to start the car I got the dreaded Service Column Lock!!!! :mad
But with the info I found on the forums, I was able to get control of it again. :cheers:
I've had most of the common C5 problems in the 7 months or so I've owned the car, and yet I still love it. whats up with that??
Old Oct 9, 2002 | 03:55 AM
Noggles's Avatar
Noggles
From: Adventure, excitement ... a Jedi craves not these things.
Cruise-In VII Veteran
Default Re: Column Lock, ARGH! (deeb0)
The car makes up for the occasional grief :)
Old Oct 9, 2002 | 07:05 AM
Ross78's Avatar
Ross78
Default Re: Column Lock, ARGH! (Noggles)
How did you UNLOCK it?
Old Oct 9, 2002 | 10:52 AM
deeb0's Avatar
deeb0
Default Re: Column Lock, ARGH! (Ross78)
The jist of how I did it was turn the key to on (but do not start). Then jerk the wheel as hard as you can left and right and curse at it alot. Then start the car and pray. Repeat several times.
if you search the forums, you'll find alot of variations of that. dunno which is the 'best' way.
Old Oct 9, 2002 | 12:52 PM
deeb0's Avatar
deeb0
So what is the best way to guarantee you never get column-locked? The dealer fix or the aftermarket bypass?
Old Oct 10, 2002 | 12:56 AM
twincam47's Avatar
twincam47
the by pass will ensure that you are not stranded out somewhere
in BFE................. :smash:
To Column Lock, ARGH!
