check engine - code P0442
Old Nov 12, 2017 | 10:40 PM
Corvette#2's Avatar
Corvette#2
Default check engine - code P0442
Today, out of the blue, the check engine light came on.
I pulled all of the codes. The only active one was 10 PCM P0442 C H.
I checked the list and it means "Evaporative Emission (EVAP) System Small Leak Detected"
I cleared the code. Went for a drive and it didn't come back.
I guess this might be my gas cap or ? I actually just replaced it like a year ago, since the original one broke and wouldn't screw down tightly.
Guess I won't worry about it unless the code comes back.
Old Nov 14, 2017 | 11:03 AM
jjc508520's Avatar
jjc508520
I went through an ordeal with this sucker (and his cousins) on my '02 4runner with 235k miles. Dealer pressurizes the entire evap system with a smoke machine and looks for leaks (brilliant!). In my case - found none - until - on a hunch - they removed the gas tank crash guard - dropped the tank a few inches - and looked above the tank with a flashlight - voila - billows of smoke found. Leaky flange where the fuel pump mounts to the gas tank....
Old Nov 16, 2017 | 06:27 PM
JBB's Avatar
JBB
EVAP small leak. Can be intermittent. Really the best way to find this is with EVAP test equipment. They use a flow meter to show IF there is actually a leak at that time & can add smoke if a leak is indicated. The most common leaks are gas cap & vent solenoid/valve.
Your local friendly garage may have the equipment to test this. Or you could round up the usual suspects. your call.
Old Nov 17, 2017 | 04:51 PM
SG Lou's Avatar
SG Lou
Did you purchase gas that day? Could be just a loose cap.
Old Nov 17, 2017 | 09:54 PM
Corvette#2's Avatar
Corvette#2
I think it was just a loose cap. The code hasn't come back since.
To check engine - code P0442
