Harmonic Balancer Question
Old Nov 17, 2017 | 05:00 AM
Grandpa1's Avatar
Grandpa1
Default Harmonic Balancer Question
I purchased my 03 Vert a few months ago. It was a one owner low mileage car. Totally stock and you could tell it was never abused.
It had 28,000 miles on it.
I've read all the horror stories about the harmonic balancer and was wondering if they all come apart?
I've looked at mine when I changed out the belts and hoses and it looks good. It doesn't wobble when it runs and appears OK.
I was also wondering if the balancer comes apart because of the way the owners hot rod their vettes.
I don't hot rod. I'm old. Don't need speed anymore.
Is it possible the harmonic balance could last a long time on my car if I don't hot rod it or is it one day going become and expensive turd?
Thanks!
Old Nov 17, 2017 | 05:57 AM
vettenuts's Avatar
vettenuts
It will usually start wobbling before anything happens. I would just check it occasionally to make sure it is running true.
Sounds like you got a good car.
Old Nov 17, 2017 | 06:30 AM
tbrowne's Avatar
tbrowne
I think most will need replacing over time, however, you're probably good up to about 50k miles or so. Hard driving might be a factor, but they fail regardless of how they are driven. Some fail suddenly without any warning, but most fail over time and give plenty of advance notice. Vettenuts is correct, just check it a couple of times a year.
Old Nov 17, 2017 | 09:36 AM
Gordy M's Avatar
Gordy M
If you want to give is a "fail test" take it to a track where you can basically run around it in third gear. Usually within on or two days it will start to wobble or walk. The vast majority of the problems are the result of rapid acceleration/deceleration by yourself or previous owners. In my case it went at 26,000 miles (12,000 miles since I bought it) but I have been autocrossing/HPDE driving my Corvette since 2002. Because I run in a stock class for autocross, I had to replace it with the OEM balancer but I pinned the crank. Since them I look at the balancer gap to the cross beam everytime I get in the car without any movement. Currently at 14,000 miles on this balancer.
Old Nov 17, 2017 | 10:12 AM
Eweco62's Avatar
Eweco62
Being new to the C5 model and used to the old C1 technology, what would you define as the death steps of the balancer. If it fails in a short time, what will you notice besides a wobble? Noise, vibration, codes? Parts flying through the hood? Just adding knowledge to the old brain.
Old Nov 17, 2017 | 10:59 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I have only heard of them going down not up through the hood. My father lost one on his '67 years ago.
I agree with others just check it a few times a year. I passed one a C5 partially because of the harmonic wobble balance 10+ years ago, and it drove just fine on the test drive. You could see it wobble with the hood open.
If it does wobble I would replace with an ATI Fluid damper and ARP bolt.
Old Nov 17, 2017 | 01:38 PM
feeder82's Avatar
feeder82
don't read about catastrophic failures often, seems most failures will give you a warning.
Old Nov 17, 2017 | 02:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The outer ring will not fly off.
As 8VETTE7 stated, it is limited in horizontal movement by the steering rack and the front cover.
When they fail the bonding between the rubber middle debonds and the ring spins on the hub. As it spins, it can move forward or rearward. Rubbing on the rack and or the cover long enough will cause you to have to replace what ever it rubs on. Read $$$$$$
Paint a white stripe across the outer ring, the rubber and the inner hub. If all is good, the white line will stay a SOLID white LINE.
If the rubber debonds, the white line will no longer line up as a solid line.
BC
Old Nov 17, 2017 | 03:28 PM
Grandpa1's Avatar
Grandpa1
Thanks Guys!
Just so happens I got a pint of white enamel paint and I'm going to nab one of my wife's little brushes and go paint a stripe on the balancer.
Good info!!
Old Nov 17, 2017 | 04:46 PM
foggy's Avatar
foggy
I got 95,000 out of my oem balancer when it started to wobble a bit..
Just check it occasionally . When you DO notice a wobble, start planning then..
Just enjoy now !!!
SG Lou's Avatar
SG Lou
Grandpa,
I got my 04 in Dec. of 2010 with 52k on the clock...HB ran as true as can be. Now I have 68k on it and it's starting to wobble pretty bad...so much so that since I heard the squeal and saw it wobbling I haven't driven it.
Drive it and enjoy it until it's starts to cause the belt to squeal and you can see it wobble.............then worry about it !
Old Nov 17, 2017 | 06:41 PM
namvet6869's Avatar
namvet6869
Just replaced mine with Powerbond balancer and ARP bolt. My 2000 had 87000 mi.
Old Nov 17, 2017 | 09:52 PM
Eweco62's Avatar
Eweco62
Good advise from all. I like the paint suggestion. This also gives me something to check when I am looking for one.
thanks!
Old Nov 18, 2017 | 12:31 AM
Corvette#2's Avatar
Corvette#2
My balancer started wobbling at only around 50k miles.
I noticed it when the belts starts squealing.
It cost about $600 parts and labor to get fixed by an independent shop. Less than a year later, the replacement balancer failed. Same shop repaired it again for free under warranty.
I have read of powerbonds going out too. I think ATI balancers seem to be the durable. But they aren't cheap.
Old Nov 18, 2017 | 12:34 AM
pjdbm's Avatar
pjdbm
I have not heard or read that yet until you just mentioned it.
Old Nov 18, 2017 | 12:47 AM
Corvette#2's Avatar
Corvette#2
Don't get me wrong, I'm sure powerbond is more reliable than the oem part. But they aren't immune to failure. The one I'm talking that went out was from someone on this forum.
Here's a youtube video too.
Old Nov 18, 2017 | 01:02 AM
pjdbm's Avatar
pjdbm
wow, I have a powerbond in a box ready to go on in a week or so, would hate to do this job twice.
One comment in this vid, he used an ATI HB and still had a slight wobble. The original poster of this vid never replied to any comments.
To Harmonic Balancer Question
Old Nov 18, 2017 | 11:05 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
A local Corvette shop told me there are two different Powerbond versions- the OEM style one (link) and the performance version (link). The OEM-style Powerbond is constructed the same way as the OEM unit, with rubber, and can fail the same way is what the guy told me. The race version is all metal.
I'd probably still go with the Powerbond OEM style one personally, it costs much less and I imagine its a bit lighter too since it's part rubber rather than all steel. I think most members here on CF seem to be happy with their Powerbond OEM style units, and failures seem to be few and far between as compared to the GM ones.
Old Nov 18, 2017 | 11:21 AM
pjdbm's Avatar
pjdbm
its the rubber in these that gives, they pretty much all have this rubber called Elastomer
Old Nov 19, 2017 | 08:02 AM
vettenuts's Avatar
vettenuts
The primary purpose is to dampen harmonics, not sure how an all metal one can do that. IMO that could be a real problem on a street driven vehicle.
Not sure who is familiar with Kurt Urban but he did work with GM when they were having timing chain issues. It was the harmonic balancer and his recommendation is either stock GM or ATI.
