Headlight close sound
Old Nov 26, 2017 | 07:28 PM
Thaddeus Snaith's Avatar
Thaddeus Snaith
Default Headlight close sound
My headlight makes a god awful when i close it. A friend told me that it was the plastic gears stripped. Is this the problem or could there be something else?
Thanks,
Tad
Old Nov 26, 2017 | 08:03 PM
Thaddeus Snaith
Default Thanks!
Originally Posted by 8VETTE7
Most likely the teeth on the gear near where the headlight door would be closed has the plastic teeth stripped off. Unlikely the motor itself would be damaged only at the close point of the headlight door.
Time to replace the gears on the motor. Here is a link on doing that.
https://www.corvetteforum.com/forums...orialized.html
There are also dozens of youtube videos about the process.
Thanks 8VETTE7, I figured that was the case. That's my first step.
Old Nov 28, 2017 | 12:38 PM
jrp1588's Avatar
jrp1588
Check ebay. I got a set of aluminum gears for pretty cheap. It's all pretty straight forward and access to the area is pretty easy.
Old Nov 28, 2017 | 12:57 PM
Velocity_Vette's Avatar
Velocity_Vette
It's pretty easy to change the gears out; don't be daunted by the task. There will be some different steps depending on if you have the early metal housing style (97- mid 00) or later plastic style (later 00- 04) but overall methodology is the same.
Rodney Dickman sells a really good completely gear kit that I recommend.
Old Nov 28, 2017 | 02:53 PM
Thaddeus Snaith
Thanks I will.
Old Nov 28, 2017 | 02:54 PM
Thaddeus Snaith
Thanks for the info.
Old Nov 28, 2017 | 02:55 PM
Thaddeus Snaith
How do I contact him?
Old Nov 28, 2017 | 03:43 PM
runner140*'s Avatar
runner140*
r
rodneydickman.com Your internet....look up headlight gears.
Old Nov 28, 2017 | 05:35 PM
Thaddeus Snaith
Originally Posted by runner140*
r
Old Nov 28, 2017 | 07:40 PM
MTWallet's Avatar
MTWallet
My drivers side gear stripped so I used Rodneys kit to replaced both sides. Top quality kit and includes everything you need including brass gears and new grease. Best $92 I ever spent.
Old Nov 28, 2017 | 07:43 PM
Thaddeus Snaith
By the way, I like your handle! It looks as though I'm going to buy his kit.
Old Nov 28, 2017 | 09:04 PM
jrp1588's Avatar
jrp1588
https://www.ebay.com/itm/Corvette-C5...RUbjAl&vxp=mtr
This is the kit I got. Includes all the same stuff, just an aluminum gear instead of brass.
Old Nov 28, 2017 | 09:11 PM
Its been a very popular kit here on the forum for years.
Old Nov 28, 2017 | 09:24 PM
Thaddeus Snaith
Interesting, is there a benefit to either aluminum or brass?
Old Nov 28, 2017 | 09:27 PM
jrp1588's Avatar
jrp1588
Cost I imagine. It probably weighs a little less. Should be way stronger than stock, so it should be good enough.
Old Nov 28, 2017 | 09:30 PM
Thaddeus Snaith
Ok thank you. That looks like another option as well.
Old Nov 29, 2017 | 04:07 AM
jdmvette's Avatar
jdmvette
Night Owl for life
I prefer the Brent franker gear. The dickman ones use rubber inserts like stock and can get chewed up just the same.
The bfranker gear does away with the rubber and that problem can't happen again.
Dickman gear
Franker gear
JMO of course i don't even run pop-ups any more
To Headlight close sound
Old Nov 29, 2017 | 09:07 AM
jrp1588's Avatar
jrp1588
I wasn't aware the rubber insert was a failure point. My nylon gears were thrashed, but the stock rubber inserts looked supply and new other than a bit of dirt and grease. I'd love to replace the whole system with some Radioflyers, I'll accept donations. haha
Old Nov 29, 2017 | 11:38 AM
GCG's Avatar
GCG
As they say, a chain is only as strong as its weakest link, and when compared to a solid brass gear the rubber insert becomes the new weakest point, but Rodney Dickman's kit includes new rubber inserts.
These inserts along with the rubber bump stops are designed to absorb the sudden shock at the end of the doors travel each time the headlights are opened or closed. Without them it's just the bump stops...
Old Nov 29, 2017 | 11:44 AM
GCG's Avatar
GCG
Here are some links to help you out: get a kit like this one (pay attention because there are 2 different kits: one for "97 to early 2000" and another for "late 2000 to 2004") and follow these step-by-step directions. You'll save money and they will last forever
You might need these as well (the rubber bump stops).
There is a TSB, that calls for shimming the driver's side motor. The parts needed for this are included in the above mentioned kit.
