Check engine light
Old Dec 7, 2017 | 11:29 AM
claf's Avatar
claf
Default Check engine light
My '04 recently popped a check engine light. On checking codes there is only one, P 0155, which is described as "Heater performance, bank2, sensor 1".
Does anyone know where to find this sensor and what it takes to replace it ? Thanks, Bob
Old Dec 7, 2017 | 12:16 PM
JR-01's Avatar
JR-01
When you clear the code does the check engine light go off? If so, I would clear it and see if it comes back on. If it does then go from there.
Old Dec 7, 2017 | 12:45 PM
Mayor111's Avatar
Mayor111
Look at Post #4 and #5 (he mentions the passenger side):
https://www.corvetteforum.com/forums...some-help.html
I hope this helps!
Old Dec 7, 2017 | 02:46 PM
Moved to C5 Tech.
To Check engine light
