starter will not disengage, even with key out
1)turn the key off, and the motor is still turning over,
2)turn the key back on and the motor runs, but makes a funny noise (Probably the starter still engaged)
3)the only way to stop all this is to disconnect the battery
I believe this to be a faulty ignition switch.
I have seen lots of switch problems, but not this specific problem.
Does it make sense that it is the ignition switch?
thanks!
IF,,,,,,,,,,,,,,,,,,,,,,,,,,,,, The wires turn up clean, the solenoid would be BAD
Bill
