C5 Headlight Issue, HELP!
Old Jan 2, 2018 | 05:43 PM
Corvette505's Avatar
Corvette505
Default C5 Headlight Issue, HELP!
Replaced the gear in my 2000 drivers Headlight, put everything back together, however now when the right headlight goes up, the left one goes down.....and vice versa. The gear can only go in one way, so that can't be it. What did i do wrong? PLEASE help
Old Jan 2, 2018 | 05:46 PM
novasscnc's Avatar
novasscnc
You tube has a good walk through, your arm is out 180 degrees
Old Jan 2, 2018 | 05:47 PM
novasscnc's Avatar
novasscnc
Set it with the lights up
Old Jan 2, 2018 | 05:57 PM
Corvette505
tried tweakin it with the lights up, adjusting the **** on end, but it still cycles thru to being exactly backward on the drivers side (when lights are turned ON, it goes down, when OFF it comes up)
Old Jan 2, 2018 | 09:05 PM
Corvette505
nova you were right, the arm was bent the other way, thanks a ton
Old Jan 2, 2018 | 09:20 PM
Moved over to the C5 Tech section.
Old Jan 3, 2018 | 08:17 AM
runner140*'s Avatar
runner140*
Originally Posted by 8VETTE7
When you are taking apart something for the first time it can be a good practice to take pictures BEFORE you begin the disassembly and also during the disassembly process.
Old Jan 3, 2018 | 12:35 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Originally Posted by runner140*
and when finished could you post them on the forum for others
to use.. thanks
mike v
Old Jan 6, 2018 | 04:33 PM
novasscnc's Avatar
novasscnc
Your welcome, when I did my first one almost drove me the nut house
Old Feb 17, 2018 | 03:25 PM
Corvette505
Replaced the gear and all that, and it worked for about two weeks. NOW, both lights go up with no issue, but when I turn them off the one i replaced the gear on (drivers side) does not go down. If I turn it back ON, then the drivers goes down while the passenger comes up, and it stays on that reverse format as I go On and Off, any clues as to what is going on? Frustrated
To C5 Headlight Issue, HELP!
By Michael S. Palmer | 2026-06-03 11:00:24
