98 c5 - dic buttons not functioning -help!!!
Old Jan 21, 2018 | 08:02 AM
ant-knee470's Avatar
ant-knee470
Default 98 c5 - dic buttons not functioning -help!!!
Hello All,
Well I got my new 98 c5 cleaned up and I am now starting on a few mechanical issues...
I just got new rims and tires on my vette, I am getting check tire system on the dash... I went to program in the new tire pressure sensors and none of the buttons are functioning at all.. when I turn key to on position it shows odometer miles and check tire pressure sensor
I am thinking it is a bad ground or a power issue... Can someone point me in the right direction of where to start here... I checked all fuses they seem fine..
Any help is appreciated
Ant...
Old Jan 21, 2018 | 05:11 PM
808_c5's Avatar
808_c5
Hey i have the same problem i am trying to figure out. Prior owner i bought the car from told me it was his gauge cluster that was the problem but before buying a whole new gauge cluster i decided to replace the buttons. Well i replaced them and in my case, it wasnt the buttons. I still can't clear the DTC or tpms message (changed my rims and tires but not the sensors, yet). Bought a working gauge cluster off ebay and hoping it'll solve my issue.
Old Jan 21, 2018 | 07:30 PM
ant-knee470
[QUOTE=808_c5;1596423575]Hey i have the same problem i am trying to figure out. Prior owner i bought the car from told me it was his gauge cluster that was the problem but before buying a whole new gauge cluster i decided to replace the buttons. Well i replaced them and in my case, it wasnt the buttons. I still can't clear the DTC or tpms message (changed my rims and tires but not the sensors, yet). Bought a working gauge cluster off ebay and hoping it'll solve my issue.[/QUOTE
Keep me posted..
If it works, Ill have mine rebuilt/serviced if I can.. Just found a used switch on craigslist.., Maybe ill pick it up...
Thanks,
Ant...
Old Feb 1, 2018 | 01:57 AM
808_c5's Avatar
808_c5
So the new replacement cluster did the trick for me
Old Feb 1, 2018 | 06:30 AM
ant-knee470
Awesome,
Glad to hear it.. Good Job..
I haven't had time to really check what's going on with mine yet, Been busy with fixing other things with in the car.. Still have few other things I am dealing with... Will get to that shortly..
Ant...
Old Feb 3, 2018 | 07:00 PM
psyop's Avatar
psyop
4th Gear
Hi,
Who did you get the cluster from on eBay?
I was looking for someone to repair the cluster in my 99, but so far I haven't found anyone who works on the Corvette clusters.
Old Feb 5, 2018 | 05:22 AM
ant-knee470
Hello Everyone,
Got the new buttons for the DIC in and still no go... Still does nothing... I pulled the BCM out to check the plugs and saw a few wires there previous owner cut... He said the cut wires are for the security system and have nothing to do with the DIC.. Well I am thinking its the gauge cluster itself now..
Can someone post a wiring schematic for the DIC so I can check and see if it is getting power or signal before I spend $400.00 to replace gauges.. would really like to get this working again.. I have check engine light on and I can't get the codes due to buttons not working..
Thanks,
Ant...
To 98 c5 - dic buttons not functioning -help!!!
