12 CD changer
Old Jan 27, 2018 | 03:51 PM
Meadows501's Avatar
Meadows501
1st Gear
Default 12 CD changer
I recently purchased a 2002 Corvette that has a 12 CD changer in the trunk. It does not eject the cartridge when the door is opened. Any suggestions short of taking it apart?
Old Jan 27, 2018 | 11:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is it properly plugged into the connector in the rear and in the front passengers foot well? Check that first. Cycle the door OPEN SHUT several times and try to select the CD played on the head unit several times.
Bill
Old Jan 28, 2018 | 04:07 PM
rrwirsi's Avatar
rrwirsi
Also, Are you sure there is an empty cartridge in the unit? If yes, then LIGHTLY tap the side of the unit with a small hammer while opening and closing the door lid. I had a cartridge stuck and using the light tap worked for me.
NFL:
Old Jan 28, 2018 | 04:23 PM
digitaloutsider's Avatar
digitaloutsider
Mine had the same issue when I first got it.
I unbolted it from the bracket, held it upside down and shook it while opening the door. The cartridge came out. It seems like it wasn't meant to be mounted at that sort of an angle and one of the trays must get caught in it. It's been fine since, but I'm sure it'll happen again.
To 12 CD changer
