LS1 vs LS2 intake manafold
Old Jan 27, 2018 | 10:08 PM
BURL's Avatar
BURL
Default LS1 vs LS2 intake manafold
Other than the larger Throttle body of the LS2 intake are there any internal differences in the two (LS1 - LS2) intakes? Runner length, size, etc. that would make the LS2 preferable for high performance use?
Old Jan 27, 2018 | 10:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As discussed and recommended many many time in the past,, use the LS6 / 2001+ manifold over the LS2 on a LS1/6 engine
What mods do you have? If close to stock, the larger TB is a waste of time as the stock TB can support 500 hp.
Bill
Old Jan 28, 2018 | 05:39 AM
Echo97vette's Avatar
Echo97vette
The ls2 intake isn't really preferable for any reason. The ls6 intake... as suggested above is a worthwhile upgrade.
Old Jan 28, 2018 | 02:56 PM
BURL's Avatar
BURL
Bill
Bill, I'm doing a forged LS block for a supercharger (Paxton up to about 12 PSI max). Probably going with an LS2 block to get the 4" bore. However I don't want to lose lose low end torque due to the car being street driven and cruising at about 1800 RPM (3.42 rear gears with A4). Probably going with a baby cam at about 220 intake duration at .050.
If the LS2 is slightly larger may be of benefit if little or no lower RPM lose of torque. Want to keep as much torque as possible until centrifugal kicks in.
Old Jan 28, 2018 | 03:05 PM
StingrayRebel's Avatar
StingrayRebel
Bill
the stock tb can support a lot more when boosted and I see the op is planning on a supercharger anyway
To LS1 vs LS2 intake manafold
