Replace CV Boot,
Old Feb 8, 2018 | 01:12 PM
jpb1978's Avatar
jpb1978
Default Replace CV Boot,
I have a leak in one of my CV boots. I am stuck trying to separate the axle from the hub. I bought an axle press but it will not do it, it just bends and deforms the lug nuts that are holding it on. Any suggestions?
Old Feb 8, 2018 | 03:09 PM
ericdwong's Avatar
ericdwong
Wow that must be really stuck! Did you try a large punch and hammer?
Old Feb 8, 2018 | 04:02 PM
jpb1978's Avatar
jpb1978
While the puller/pusher was loaded I hammered on the bolt and nothing moved at all. I have talked to some local vette guys and they said theirs came right apart. I sprayed it with PB nut buster and put it back together, will try again in a few days.
Old Feb 8, 2018 | 06:05 PM
jpb1978's Avatar
jpb1978
I hope mine doesn't end up being this hard.
Old Feb 8, 2018 | 09:06 PM
Ed Ramberger's Avatar
Ed Ramberger
Buy a can of Kroil from Kano Industries. It is what we use in industry in many applications. Best product for penetrating and breaking down rust you will most likely ever use.
Old Nov 15, 2018 | 06:52 PM
jpb1978's Avatar
jpb1978
So the weather has cooled in Florida so I decided to try this again. I took the nut off last March and filled the gap with Kroil, when I took the nut off today it was still in there. I put the tool J-4212S on the hub and started cranking, I heard a loud pop and thought it had moved, nope.
Any more suggestions?
Old Nov 15, 2018 | 07:26 PM
chris308's Avatar
chris308
Heat? Try torching it...
Old Nov 15, 2018 | 07:48 PM
jpb1978's Avatar
jpb1978
I would have to heat the hub bearing assy, don't really want to do that. Yet. I suppose I could try taking the axle and hub out as a unit and try to get it into a press. But lots of fragile aluminum to worry about doing that.
Old Nov 17, 2018 | 09:48 AM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
I did mine about 7 years ago, cajandudes method, don't remember it being that tough. But if I remember right, took nut off and freed the shaft with car on the ground with a 10 lbs siege hammer. I elected to install a new shaft as opposed to changing the boot, so wrecking the shaft threads was not an issue.The tough part for me was getting the shaft out of the differential. Removed the upper control arm from the frame as opposed the messing with the ball joint. Looked like a lot of work to change the boot, compared to the cost of new shaft. Good luck.
Old Nov 20, 2018 | 03:16 PM
gearheadib's Avatar
gearheadib
A good air hammer
Old Nov 20, 2018 | 05:02 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Originally Posted by gearheadib
A good air hammer
To Replace CV Boot,
