column lock
Old Feb 14, 2018 | 01:27 PM
mmartinez's Avatar
mmartinez
Default column lock
Needing advice on my 97 m6 which I have owned for 11 years now. Wanting to be proactive what should I do to prevent future problems with the column lock mechanism. The car has 104k miles presently and the column lock still works as intended, I will say I had one instance in 11 years where I had to jerk the steering wheel hard against the stops to get it to unlock. Should I be proactive or leave something that is working alone? Any advise will be appreciated.
Old Feb 14, 2018 | 01:51 PM
feeder82's Avatar
feeder82
Get the LMC5 from Compliance Parts and be worry free
Old Feb 14, 2018 | 04:53 PM
mmartinez's Avatar
mmartinez
Thanks for the reply, I will be buying one and the unlocker and keep them in the car for peace of mind.
Old Feb 15, 2018 | 11:30 AM
Nate@VanBortelChevy's Avatar
Nate@VanBortelChevy
Platinum Supporting Dealership
Lmc5!
Old Feb 15, 2018 | 01:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
"I will be buying one and the unlocker and keep them in the car for peace of mind"
Installing the LMC5 isn't difficult but it ISNT a 2 min job. When you get it, take the good part of a Sat morning and INSTALL IT.
What are you going to do when you are on the road away from home and have to be at a specific place at a specific time and the column lock decided that its going to fail and NOT unlock?????
Bill
Old Feb 17, 2018 | 01:29 PM
mmartinez's Avatar
mmartinez
I have already ordered the LMC5 and planning to install it, even thou the pull key message has not reappeared the last three weeks, and I have used the car about 3 to 4 times a week. Just curious as to what else can trigger the pull key message besides the column lock, any insight? Thanks for your advise.
Old Feb 17, 2018 | 02:29 PM
Smoken1's Avatar
Smoken1
A battery that is weak
Old Feb 17, 2018 | 07:40 PM
mmartinez's Avatar
mmartinez
I have one last question about the LMC5, my car is a 97 m6, does the LMC5 prevent the steering wheel from locking after installing, or does it just prevent the pull key message.
Old Feb 17, 2018 | 08:14 PM
grassblaster's Avatar
grassblaster
Yet another thing I procrastinate on. my lock seems to be working. Running a AGM battery.
Old Feb 17, 2018 | 09:31 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you install ANY of the Column Lock By Pass modules, it prevents the column from ever locking again.
IF,,,,,,,,,,,,,,,,,,, Your car ever had the GM recall done, you should have had the modified locking plate installed during that recall that prevented the lock from locking the wheel. If your wheel still locks, you do not have the recall done or the full recall accomplished.
The lock motor must still work because the installation of the locking device requires the lock motor to RETRACT the lock pin and once its retracted the bypass is installed and that electronically simulates the lock motor working.
Bill
Old Feb 17, 2018 | 10:26 PM
grassblaster
I have a manual. And my column still locks.
I should prob get around to doing the lmc5, but haven't yet.
Old Feb 17, 2018 | 10:34 PM
RIKKI Z-06's Avatar
RIKKI Z-06
Mine worked great on a Friday, Monday morning came and guess what? Took me 30 minutes to install, no more problems.
Old Feb 18, 2018 | 10:25 AM
mmartinez's Avatar
mmartinez
Thanks to all for your knowledge on this subject, as stated my car is a 97 m6 c5, and I purchased in 2006. I am pretty sure that it has not had any of the factory recalls dealing with the column lock done, I have two GM campaign stickers on the inner fender well they are 97040 and 97031, can someone tell me what those two were for. I have already ordered the LMC5, just in case I need it, but I am on the fence about defeating a theft deterrent feature that is presently still working. I know, I know that I may be stranded if it fails sometime in the future. Again thanks for all your help on this subject.
Old Feb 20, 2018 | 03:17 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Glad you're a gamblin man. Nothing like being stuck in a dark strange place with no cell phone at midnight.
Old Feb 20, 2018 | 11:18 AM
mmartinez's Avatar
mmartinez
Roll the dice!!!
Old Feb 21, 2018 | 01:38 AM
laurent_zo6
Roll the dice!!!
I put in a LMC5 as soon as I bought my car. I had enough to worry about driving on 11 year old tires for a month. .
To column lock
