If you've put an LS2 TB on an LS1 please step inside...
I'm currently in the process of getting all of my ducks in a row for my H/C/I, LT Headers, etc. build on my 2002 C5. I recently bought a used LS2 TB from a 2006 C6 on eBay. It was sold as a functioning pull off part. I was going to send it off to Vmax for porting, and they recommended that I test the part before sending it in because they've seen high failure rates for LS2 TB's. Right now I do not have a way of testing it on a car.
I'm wondering if anyone on here has had issues with LS2 TB's, and how do they run untuned on an LS1? I want to be able to diagnose any problems on the completed engine without introducing the possibility of a faulty TB. I might end up starting it initially with the LS6 TB/intake just to make sure everything runs right. What do you guys think?
I was going to do this mod , this will need to be done if you want to keep the ls6 intake .. dorman makes one but looks ugly.. only issues I read about was if you get a gold blade throttle body instead of a silver blade the ls1s don't like it, but silver blade with the ls1 to ls2 plug connectors it will work fine..
I'm actually on the fence between the TPIS and the Fast 92. There have to be a lot of people running the TPIS, but there isn't a lot of data out there on it. I like the idea of OEM fitment with a 90mm snout. If you have any experience with TPIS or could point me in the right direction I'd appreciate it.
Code:
p
Thanks for the Reply. I do have the silver blade TB with the wiring harness, so I should be good.
Code:
p
Code:
p
It does help. I pulled the trigger on a ported Vengeance Fast 92 during their tax sale. This also gives me the opportunity to initially test the car with the stock LS6 setup or Fast 92/90 setup. I really didn't want to do the Fast, but I knew I'd regret not having one down the road. Do it once, do it right...
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
An unported LS2 TB works fine on the LS engine. My tuner prefers the UN-PORTED TB because it tunes MUCH easier.
