C5 Half Shaft Boot Replacement
Old Mar 12, 2018 | 01:31 PM
nsogiba's Avatar
nsogiba
Default C5 Half Shaft Boot Replacement
I have a tiny tear in the passenger inner (diff side) rubber boot on the half shaft. It has been slinging grease for a few months now.
It is possible to remove and disassemble the half shaft to replace only the boot? I did this on a Subaru and it worked like a charm. Prefer not to have to replace the entire half shaft...
Car is a 2000 FRC 6 speed if it matters.
Old Mar 12, 2018 | 04:00 PM
zachaeous's Avatar
zachaeous
Yes it is possible to remove and replace the boots. I believe the boots are no longer available from GM. I do believe there are aftermarket boots that are available.
Old Mar 13, 2018 | 04:12 PM
nsogiba's Avatar
nsogiba
It looks like these are the part numbers, I wasn't able to find any through the usual online parts suppliers like GMPartsDirect and so on...
https://www.corvetteforum.com/forums...post1574036595
Originally Posted by Eric D
From any dealer or from a forum supplier you are looking for part #88952506 for the outer and #88952507 for the inner. The service manual covers replacement.
Old Mar 14, 2018 | 08:19 AM
jumpmanmb87's Avatar
jumpmanmb87
The inners are discontinued, the outer ones are getting impossible to find as well, just did my outer ones in NOV. Need the crimp pliers for the band clamp
Old Mar 14, 2018 | 08:29 AM
nsogiba's Avatar
nsogiba
What about aftermarket replacements? I've read that the reman axles use boots that are floppy and tear because they touch stationary components. The slip-on split style are crap of course.
I wonder if I can just use some heavy duty silicone to seal the tiny hole. Saw a video where Froggy did that...
Old Mar 14, 2018 | 08:55 AM
GUSTO14's Avatar
GUSTO14
Auto Parts Warehouse has them with free shipping if you spend $50...
86-2348-D CV Boot - Black, Direct Fit, Rear, Passenger Side, Inner - $11
86-2337-D CV Boot - Black, Direct Fit, Rear, Outer - $12
86-2349-D CV Boot - Black, Direct Fit, Rear, Passenger Side, Outer $11
Good luck... GUSTO
Old Mar 14, 2018 | 08:58 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by nsogiba
...I wonder if I can just use some heavy duty silicone to seal the tiny hole. Saw a video where Froggy did that...
It's certainly worth trying until you can get around to replacing it. Be sure to get the boot very clean to get the silicone to stick.
GUSTO
Old Mar 14, 2018 | 01:14 PM
nsogiba's Avatar
nsogiba
Since there is no agreed upon replacement for the boot, I'll be the guinea pig. I'll measure my factory boot tonight (the subframe is pulled out the car) and compare to the manufacturer's drawing. If it look like it'll work, I'll order one up and see how it looks.
https://www.autopartswarehouse.com/s...MP862348D.html
Note: One of the Amazon reviews for this part number states that the buyer used it on his 2012 Acura TL 6 speed. Might have a chance for cross-referencing...Rockauto shows BECK/ARNLEY 1033104 {#44017TK5A51} as an available part for that car.
Amazon Amazon
Old Mar 14, 2018 | 09:11 PM
Sam Handwich's Avatar
Sam Handwich
GUSTO
I would NOT recommend silicone seal. While you definitely need to clean the area well, I think you will get much better results with urethane sealant (NOT polyurethane). It is available as windshield sealant, so it will be black. I have used the 3M marine seal (which is a urethane) and it outperforms Silicone seal for almost any application (IMO)
Old Mar 14, 2018 | 09:57 PM
jpb1978's Avatar
jpb1978
I used this on my cut boot, I cleaned it very well with rubbing alcohol, put on the sealant and let it sit for a couple days, have about 2k miles on it and holding up fine. I have the factory repair kit on hand.
http://www.bowessealfast.com/p-579-p...YaAn1BEALw_wcB
To C5 Half Shaft Boot Replacement
