LS2 TB Fast 92 problems
Old Mar 17, 2018 | 08:06 PM
evolmotorsprt's Avatar
evolmotorsprt
I was under the impression that you need the silver blade or no worky
Old Mar 20, 2018 | 02:04 PM
magnoman's Avatar
magnoman
Ok So have new TB and it works! But looks like throttle blade not opening fully ? maybe 90%
Is that something that can be fix in tune ?
Old Mar 20, 2018 | 02:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Mar 20, 2018 | 03:30 PM
magnoman's Avatar
magnoman
Runs good HP scanner show 100% TPS open and no Limp mode ! know only issue HP scanner not reading rpm ? Kind of hard to tune ?
Inserted inserted Go Point Blue tooth ODB11 and rpm reads fine on phone app .. so ECU putting out the info .
Old Mar 20, 2018 | 04:15 PM
SVT_Z06's Avatar
SVT_Z06
Told ya! Nice job.
Did you figure out the 90% thing or was that just something that you visibly saw but was incaccurate?
Not sure about RPM...post the hpl file.
Old Mar 20, 2018 | 04:38 PM
magnoman's Avatar
magnoman
Well yes visibly did not seem to be opening full but HP Scanner say 98-100% ?
Have RPM back in scanner for some reason RPM channel not set to "SAE" who know runs great but still having my tuner run through the tune in few weeks while car is in shop for clutch .
Thanks for everyones help ! lot of wasted time on bad ebay part ..a lesson learned .
Old Mar 20, 2018 | 05:06 PM
SVT_Z06's Avatar
SVT_Z06
Outstanding!
I don't have the mods you have, but boy, the LS2 TB added some power. I'll find out more when I hit the track.
Old Mar 20, 2018 | 07:13 PM
magnoman's Avatar
magnoman
This mod feels better than all the work and extra comp ratio than the ported heads had on car .
Just read a thread where guy was getting 29 extra rwhp and 20 ft lbs of tq ?
Will find out when get car on dyno .
A bit concerned about not getting actual WOT on physical TB but ECU reporting is is 100% .
Can’t find any info on that
Old Mar 20, 2018 | 10:23 PM
SVT_Z06's Avatar
SVT_Z06
I just took a video of mine opening all the way I'll post it in a bit.
It should open all the way. Maybe you can post a video too? If it doesn't, it's defective. When I looked at your tune, the scaler was .182. Did you change that?
Not sure how much I gained, but it feels like I gained torque and horsepower at all rpms. Gains are low and high. Very, very pleased.
Old Mar 21, 2018 | 12:21 AM
magnoman's Avatar
magnoman
Yes did change scaler to 192 .
Will take video of it on car .
Old Mar 21, 2018 | 12:48 AM
SVT_Z06's Avatar
SVT_Z06
Default Here's my video
Watch "LS2 Throttle body opening test" on YouTube
https://youtu.be/jLC5wFL4Z_A
