LS2 TB Fast 92 problems
Old Mar 14, 2018 | 11:30 PM
magnoman's Avatar
magnoman
Default LS2 TB Fast 92 problems
Installed a Fast 92 & Gold Ls2 TB on my 02Z . At first had issue @ WOT going into limp mode was told I need silver blade LS2 TB that Ls2 Gold will not work .
Purchased a silver LS2 TB and know problem is worse . i did HP tuners scan get to about 42% throttle position and goes into limp mode code 1220 ?
With the Ls2 Gold TB get to about 98% Throttle position and then shuts down.
I did continuity test on adaptor harness all seem good . Have TPS scalar @ 192 fuel trims look good car idles good .
A bit baffled and about togo back to OEM intake and TB .
Old Mar 15, 2018 | 06:29 AM
jumpmanmb87's Avatar
jumpmanmb87
What part # LS2 TB you using below are the correct ones that work
GM# 12570790
AC Delco #217-1617
Old Mar 15, 2018 | 09:03 AM
magnoman's Avatar
magnoman
The PN TB I have is : GM 12570790 from a 05 GTO
Harness #108115 .
Don't know ..
Old Mar 15, 2018 | 09:32 AM
SVT_Z06's Avatar
SVT_Z06
You need to raise the P1514 values higher than your map readings. Multiply by 1.5. Report back.
Old Mar 15, 2018 | 09:52 AM
SVT_Z06's Avatar
SVT_Z06
Post your tune as well.
Old Mar 15, 2018 | 09:55 AM
magnoman's Avatar
magnoman
Ok will try but ,
I can have HP scanner attached car not running step on throttle and watch the TPS % it gets to 42% and immediately goes into limp and get 1220 DTC .
Old Mar 15, 2018 | 10:04 AM
SVT_Z06's Avatar
SVT_Z06
Try what i suggested and report back.
magnoman's Avatar
magnoman
Ok ,
Old Mar 15, 2018 | 11:20 AM
magnoman's Avatar
magnoman
Same issue .
gets to 42% Throttle and limp mode and know I have check engine light can not clear and strange humming noise coming from pass side where ECU is had to pull battery lead .. Just wonderful hope did not brick ECU !!!!!!!!
Old Mar 15, 2018 | 11:25 AM
magnoman's Avatar
magnoman
Also cant write tune it fails
Old Mar 15, 2018 | 12:09 PM
magnoman's Avatar
magnoman
Had low battery put charger on ECU ok know .
I tried the Gold blade LS2 TB it seems to work better gets all the way up to 98% Throttle position then get Limp and 1515 Electronic Throttle position .
This is very strange why would Gold TB work better .
Read that not all C5 ECUs are wired all the same ? I have 02Z ?
Old Mar 15, 2018 | 12:21 PM
SVT_Z06's Avatar
SVT_Z06
Very strange. Gold blades shouldn't work.
Increase the p1514 values more and see if you can get rid of the code. Try 15% more. Do this with the gold blade.
Old Mar 15, 2018 | 12:24 PM
SVT_Z06's Avatar
SVT_Z06
Pm me your tune.
Old Mar 15, 2018 | 12:41 PM
magnoman's Avatar
magnoman
cant seem to find where to attach file to PM ?
Old Mar 15, 2018 | 01:43 PM
SVT_Z06's Avatar
SVT_Z06
Just sent you what to do. Give it a shot.
Old Mar 15, 2018 | 02:01 PM
RedRiderZR1's Avatar
RedRiderZR1
Can't seem to attach files to PMs. Functionality not there in PMs, only posts. Here is a test you should do. If you still have the stock TB, hook that back up and scan that TB (multiple 0-100% throttle openings). Look at the voltages and throttle angle, then hook up each of the other TBs and do the same test and look at the areas that you get the codes and Reduced power mode. The TAC expects to see a certain throttle angle at a certain voltage. If there is a big enough difference between the stock TB and these other TBs, that is where your error is possibly coming from. There is some adjustment you can make if this is where your errors are coming from. Put your scans up here so we can better help you. Also, have seen posts about the gold blade having a bit of flutter at the blade at WOT. Not sure if that is true or not, but if it does, that flutter will change the blade opening and then the TAC will throw a code. On the gold blade, throttle 100% and have someone check if there is movement.
Old Mar 15, 2018 | 03:44 PM
magnoman's Avatar
magnoman
I tired adjusting TPS high & low fail as suggested by SVTZ06 made no difference .
I cant seem to add the TPS voltage PID to scanner to monitor TPS voltage .
To LS2 TB Fast 92 problems
Old Mar 15, 2018 | 04:09 PM
magnoman's Avatar
magnoman
Default LS1 to LS2 TB Problems
scans & Tune attached
Old Mar 17, 2018 | 12:56 AM
SVT_Z06's Avatar
SVT_Z06
I just installed and tuned my new LS2 silver blade today. Zero issues at WOT. See if you can get another throttle body. Return the one you have.
Old Mar 17, 2018 | 08:43 AM
magnoman's Avatar
magnoman
Have a new one on the way hope it works ..
Thanks ,
