Lighting electrical help!
Old Mar 18, 2018 | 11:19 AM
Marrigo's Avatar
Marrigo
4th Gear
Default Lighting electrical help!
Hello! I am finishing up my winter project of replacing hvac module. This requires removing the dash. After completing repair (s) I assembled just enough to safely run the car so I can evacuate and recharge the a/c. Now I have a problem where my dash, rear parking lights, and drl lights are always on (even when the key is out) all switches are turned off. I also notice that I have power to the fog light switch (can turn them on/off) even when the key is not in the ignition. Also, when the door is open, I am getting the fast chime (like when you leave the lightstate on) even when all switches are off and key is in my hand.....help!
Old Mar 18, 2018 | 10:22 PM
FX VETTE's Avatar
FX VETTE
Pull the codes to see if you forgot to hook a connection back during repair.
Unhook the battery for 30 minutes, then hook it back up.
