'04 Alternator Not Charging
Currently, the alternator only excites if I disconnect and reconnect the connector a certain way. Like i have to tug on the harness while connecting it.
Now for the background and what I've done...
I had no issues for about a year after I bought the car. It started as an overvoltage issue that I traced down to the fusible link at the started for pin D. I gave it a little tug and it pulled right out of the terminal. Replaced it, no more "high voltage" readings when I hit bumps. But that was the start of the not exciting issue.
I've hit the terminals with a multimeter, big red wire reads battery voltage, pin d reads battery voltage. I don't exactly remember the L and F terminal outputs, and I don't know what they are supposed to be. One read 10 something volts and the other was millivolts if I remember right.
Anyways, I thought it was something wrong with the D wire since that's where the issue started so I ran a direct battery to alternator with a fusible link with no luck. Same issue.
I've checked and double checked the lug on the starter. The big wire has a little corrosion on the terminal, but not enough to where it would cause any problems I think. I've replaced the alternator twice, so that's out of the picture. I replaced the pigtail connector with no luck either.
I'm at my wits end with this, just wanted some advice before I finally call it quits and take it to a dealership. I just know it'll be difficult explaining all this to them if I do.
I attached the wiring schematic.
Mine I tested with a volt meter and clean voltage across the board.
I asked BC about my 04 because the bearings are starting to make noise and he said it does have the special circuitry in it that many posts reference. I have read many posts about alternators from Advance, Auto Zone, O'Reilleys that don't excite properly but unfortunately the GM alternator has been turned in. There is one thread where the OP went through three then just bought an OE alternator and it was fixed. Bill told me to have my alternator rebuilt at a professional shop rather than turn it in to a chain store and hope they got it right.
I trust them completely.
I even told them I could bring in the valeo voltage regulator for the rebuild and all stated they wouldn't allow that. Sending it out of state to fix was to costly and hate that for warranty purposes.
This other post has detailed info on the rebuild procedure and links to get the other parts.
There is no special circuit inside the alternator. The regulator just works at different voltage levels compared to the rebuilds. The Corvette PCM only provides 10V at a limited current on the L wire so the regulator has to be able to work with that signal since it's the signal that excites the alternator.
If you have one of those test lights with a probe, try connecting it between power and the L terminal at the alternator before starting it. You may need a helper to start the car while you hold the light backprobed into the connector. You could also just try revving it after starting and see if the alternator kicks in once a higher rpm is reached. If both tests are successful then that indicate its the regulator.
Got my hands on an OE alternator my buddy had in a race car that he didn't mind trading. No more problems with exciting!!
Thanks for the advice everyone!
